Old October 26th 2003, 06:44
MattKab's Avatar
MattKab MattKab is offline
Lightbulb equal length T rods on a BJ Bug
Could the problem of bump-steer be near eliminated by having two track-rods of equal length?
If you look at the steering mechanism on both torsion bar T1's, steering box '02/'03 and R+P '03.
Integrate elements of each into a new system for a relatively un-modified torsion bar front. Fuel tank may need raising or replacing.
If you Use the idea of using a second stripped out steering box as an idler mount (Like Steve C's hill climb friend). Connect the two Pitman arms with a length adjustable idler. Attach the steering dampner and equal length Track rods to the idler. A symmetric steering response? Could it work better?
Matt
Old October 26th 2003, 14:48
Bruce2 Bruce2 is offline
Now if instead of two short tie rods, you got two long tie rods and connected the right steering box to the left spindle, and the left steering box to the right wheel (like stock), then you'd have almost no bump steer at all. But I bet the criss-crossing tie rods would interfere with each other.
Old October 27th 2003, 11:46
craazy Cooter's Avatar
you're damn right. Also when the car is on the ground, the tie rods need to be level to the pavement. this will also eliminate bump steer.
Old October 27th 2003, 15:39
MattKab's Avatar
Bruce Sorry I meant to quote you post, not edit it
Old October 28th 2003, 18:26
Originally posted by Bruce2
Who mentioned short rods?
I was proposing a symmetrical steering arrangement with EQUAL T rods, mounted symmetrically to the idler! Like on an R+P '03. I fail to see the 'stupidity'. Lowered Super's don't suffer anywhere near as bad BS with their superior central steering. The motion of the steering arms is identical LHD and RHD
I not convinced bump-steer can be eliminated altogether. The biggest problem is the bump-steer being so unacceptable on the drivers side.
To anyone reading this thread, this is not my reply, its Matt's. As a forum administrator he has the ability to edit other people's posts and has apparently done so here.
Old October 28th 2003, 18:32
In my original reply I stated that I thought it was a really stupid idea to eliminate the long (good) tie rod and replace it with a short (bad) tie rod.
I can't see how you could do a dual steering box steering arrangement without using only short tie rods. If you have any information on how you could do it with long tie rods, show us here.
Old October 28th 2003, 21:26
MattKab's Avatar
I'm with you on the long (good) 'rod, think medium
akin to
As an Engineer I appreciate the need to address the resultant lengths of each steering member. Porsche's kompact 'tank straddling, bootspace earning steering and <25hp was never meant to be a race car. And Bumpsteer was inherent. I'm sure Prof. Porsche was aware of this and made a 'note to self' struts und 'rack for T4 Beetles!
