coil over owners
are you happy with your coil overs? im looking for something better than stock performance. all of the info i read is that they are only marginaly better. do they give a smoother ride? i cant see why pay for such items when the performance isnt that much greater. am i completely wrong here? who uses them and what setup do you have?
neil |
The bigest advantage of coil overs is the ability to adjust ride height and change springs easily to suit conditions. Much easier than lowering/raising with the torsion bars or swaping out torsion bars to a different spring rate. Coil over springs can be had in progressive rates also, softer for the first inch or two of compression then stiffen up for more aggressive driving.
ken |
Can also use widwe rims.
T4 2666 1303s |
And it is also easy when you have to cut through the torsionhousing if you want to put an another tranny under your bug...
Grt. Wiebrand
B-Extreme B-Tuning..... Racebug is comming to get ya!!! |
