24mm good enough?
Will the stock T4 oil pump be good enough for a 2.7engine? Enough pressure with 2 oil coolers, one at the front of the car, the other on top of the gearbox?
T4 2666 1303s |
Hi,
Are you familiar with Gerd Tafel's car? He's is a well known tuner in Germany and his 2733 cc puts out about 225 streetable hp in his mex. 0-62 mph in 4,5 seconds !! He uses the stock 24mm pump only... You may or may not make up your own conclusions. Take care, Walter |
I'll use it and see how it goes! Guess should be alright! Thanks Wally.
T4 2666 1303s |
It has everything to do with your internal tolerances. small pumps need tighter tolerances for adequate oil pressure.
I run looser tolerances and bigger pumps, keeps things nice and wet.
Jake Raby |
Thanks Jake, I have 30mm and stock T4 pump will try both. I like it tight,nice and wet too!
Do I need to fill up to level for oil to test or is there a min. level?
T4 2666 1303s |
