Old July 28th 2002, 13:51
Dan Zink Dan Zink is offline
adapting brembos to CB kit ?
Has anyone looked at what it would take to bolt Brembo calipers (of any sort) to the CB disc brake kit ?
Front and rear ?
Thanks, Dan
1965 Bug - 2600cc FI - GL
1965 Notch - 2300cc
http://users.aol.com/my65notch/index.htm
Old July 28th 2002, 14:25
bugsoup bugsoup is offline
I am currently trying to install 996 calipers front and rear with the CB spindles. I plan to make custom adapter blocks once I get the rotors mounted. When I get them sorted out, I will let you know what my solution is.
thanks
Scott
My Blog
Please help me get a minimac
Parts I Need
1965 Beetle "Gordie", 1956 GL Beetle
Old July 28th 2002, 14:32
rumor is - that the 944t calipers will bolt right up to the cb front spindles (which are late ghia ? not sure)
If that's so - what rotors to use ?
Thanks for the info on the rears.
keep me posted.
Thanks, Dan
1965 Notch - 2300cc
Old July 29th 2002, 15:41
Alex's Avatar
Alex Alex is offline
You have to do minor mods to the spindle to bolt up 944T calipers.
You have to cut away the lower thread....mill or spot face the material next to it to the same thickness of the top thread....drill a new hole for the lower bolt and tap both holes to M12 I believe.
I suugest tapping the upper hole, mounting the disk and see where you need to take the material off and where to drill.
You also need to space out the caliper with a washer to center it properly.
Old July 29th 2002, 15:59
Tech article
Dan,
I think that this will be a topic in the up coming 'Tech' articles of the main site.
There are enough people who have done this conversion so having the information in one spot makes sence.
Old July 29th 2002, 21:12
I can't wait !!
1965 Notch - 2300cc
Old July 29th 2002, 21:32
so........should I be at the salvage yard scaring up some 944t front and rear calipers ?
1965 Notch - 2300cc
Old July 30th 2002, 00:40
I have yet to find a local salvage yard that has Porsches and is willing to give a reasonable deal. But that could be just my area and bad luck. Try ebay and the Porsche forums. I've gotten a few parts at good prices.
Try http://www.rennlist.com/ads/ and http://forums.pelicanparts.com/forum...p?s=&forumid=5
They have both been pretty good to me.
thanks
Scott
My Blog
Parts I Need
