Old January 1st 2004, 10:16
petevw's Avatar
petevw petevw is offline
Question electrical problem with 911 fan? power surging up and down.
as soon as i hit 2000rpm everthing surges from like 10.5-13.7 volts causing my entire electrical system to "fade in--> fade out". the lights dim/brighten, fuel pump surges loud/quite, etc...
have a 911 fan. maybe i hooked it up wrong? how should the voltage reg be done. car had a generator before. but, this has happened this year. last summer it was fine.
thanks,
pete
'72 super
'65 bus
'52 split
Old January 1st 2004, 11:39
Alex's Avatar
Alex Alex is offline
Sounds to me like the regulator is gone.
I had the problem once with my T1 in 91.
Old January 1st 2004, 17:32
CLKWRK's Avatar
CLKWRK CLKWRK is offline
You had it working before, right?
Check that everything is properly grounded. see if you can get your hands on a working reg and swap it in. If the problem is still there, then keep looking elsewhere, brushes, rectifier, etc.
hope that helps
Bry
GL ghia restoration:
Old March 29th 2004, 03:29
paulgrey's Avatar
paulgrey paulgrey is offline
I once found that a brush wasn't contacing properly on the armature, make sure the brush springs are all ok.
Phat cars = Skinny chicks !!!!!!!!!!!
Paul Grey
Auckland, New Zealand
paulgnz@hotmail.com
