Old April 23rd 2004, 15:45
pantswagen pantswagen is offline
944 turbo rear in a splitty
I have had the spring plates modified for irs
i have some type 4 drive shafts 17 ins
the question is- can i use bug irs a arms and cv's and splined shafts
in these hubs, then get some 944 or aftermarket caliper mounts?
i intend on using twin pots upfront on a splitty
where in the world can i get some front caliper mounts?
thanks
Old May 3rd 2004, 21:33
Shadowbug's Avatar
its been sone with the 944 allot arms, but he had to disassemble the rear suspension to change the tires.
a few pics of my project
Old May 6th 2004, 18:41
Question was he using 9 inch wheels or 7's?
i'm getting there - i think!
Old May 7th 2004, 22:28
Pillow's Avatar
Pillow Pillow is offline
Call up Russell at Old Speed (www.oldspeed.com) for the front fitment of 944 brakes. It is very easy!
On the rear I have no idea what ride height you want so it is hard to answer that question.
I am running a little bit of the Old Speed kit (modified swing plates) and then the Bus Boys adjustable control arm mounts. The Bus Boys clamps are the only way to go in my opinion. T1 IRS arms with 944 stub axles, Thing output flanges on the tranny, SAW floating axles, and T2 CVs.
With my setup I am staying at stock hieght and running 15" Phone Dials. No problem getting the wheels off the rear. But with Turbo brakes you need at least 16" wheels... If you drop it expect tire removal issues.
My issue now is upper shock mounting brackets... Grrr!
Good Luck,
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old May 9th 2004, 00:43
Bullyboy Bullyboy is offline
Creative engineering makes them, bolt on or weld them.
http://www.creative-engineering.com/...=7661390_12258
I really like their IRS system exept, I have to find a 68-69 bus to yank the bits off of.
Old May 11th 2004, 04:39
paul_f's Avatar
paul_f paul_f is offline
Pillow,
Use Russ's top shock mounts - or if you have a lathe make your own. They are a piece of 20mm round stock about 25mm in length and tapped in the centre which you weld to the underside of the chassis rail, where the u shaped support is. I then used Mini front shocks due to the reduced distance.
Anything else will knock the bushes out of the shocks rapidly
Russ doesn't charge a lot for these
Paul
