Old July 21st 2004, 11:58
Soul Soul is offline
944 rear e-brake shoes
I've heard that you can use replacement drum brake shoes from a volvo for the e-brake shoes on the 944 trailing arm swap. Can anyone confirm that this is indeed true? If true, what year and model car? Any help will be greatly appreciated.
Old July 22nd 2004, 20:48
Jeza Jeza is offline
Soul
I believe it is actually BMW shoes, they run a similar handbrake setup in one of there cars. From what I've heard these are cheaper than the Porsche replacements.
Sorry I don't know models or years - but a search looking for BMW shoes may show something.
Cheers
Jeremy
1302 RAt "GermanLook"
Old July 22nd 2004, 21:02
Typ Vier Typ Vier is offline
Soul,
I used BMW brake shoes for models 525I, 530I, 535I, 730I, 735i, 745I from model year 85 on. These models use the same brake shoes as the 944 does.
See ya
Andreas
Andreas
Old July 23rd 2004, 10:24
Thanks Andreas, you just saved me some serious coin!
Old July 25th 2004, 02:23
Superman
There is no reason to use Volvo, BMW, or other brake shoes. The 76-85 924/944 and 68-79 Bug/Superbug use the same rear brake shoes, 113 609 537C is the VW part number.
Old July 25th 2004, 05:51
Superman
The little shoes inside the rear rotor of a 944 set up are the ones Soul was after, for the handbrake.
VW wouldn't have made these, would they?
Jeremy
Old July 25th 2004, 09:31
Superman,
I have the 86 arms. The VW brake shoe diameter is a little bigger than the Porsche one, also the the bottom of the VW shoe is square and the Porsche one is trianglar where it rests on a molded block on the trailing arm housing. Looking at the picture on Pelican Parts website I would call the shoes identical, however looking at them side by side there are obvious differences. Hell I got pretty excited there for a moment! I'd rather pay $14.00 for e-brake shoes than $120.00 for the Porsche ones!
Last edited by Soul; July 25th 2004 at 09:39. Reason: the trailing arms I have are 86, reply was about 76-85 arms, and I can't freakin' spell correctly!
Old July 26th 2004, 23:17
boygenius's Avatar
Well are the 86 and later energency brake shoes used on anything alse or are those who chose to use the early/late aluminum arms stuck with paying Porsche prices.
Old July 31st 2004, 08:40
pantswagen pantswagen is offline
shoes
why not get your originals re-lined
5 bucks do it yoursely
Old August 1st 2004, 12:00
Can you please expound how you can DIY for $5.00? Any explanation would be greatly appreciated.
I'm leaning towards grinding the metal portion of the Beetle shoe to match the shape of the 944 shoe, since all the other mounting tabs/locations are the same. I just haven't gotten around to trying it out yet. I'll let you know how it turns out once I've completed it.
Old August 1st 2004, 19:49
Paid NZ$ 55 @ BNT for aftermarket New! Brake shoes. Should be around USD 30, is it really worth the time modifying something that may not work properly???
Andreas
Old August 1st 2004, 20:30
If you can find the pad material you can brad rivet it onto the shoes you have. The last time I did that was on a private aircraft as the "practical" test for my A&P license. It was a cheap eazy way to do it.
Old August 2nd 2004, 10:01
It would only take a few minutes with the grinder to replicate the shape. Plus I have a few old VW shoes laying around. If it worked out I could always duplicate the shape to a new set of shoes that I have. I can get the BMW shoes for $34.99 from www.rockauto.com, but if all it takes is to remove a little metal to get the VW shoes to work, that $34.99 can go towards other stuff...like beer! :haveadrin
