Old November 14th 2004, 16:14
miller's Avatar
miller miller is offline
Some tube questions.
Assuming all the numbers are equal whats stronger. A tube with a big diameter and thin walls or a tube with a small diameter and thick walls? And would this be the same for square tubing as well?
67ghia, 2.3T mid engine conversion, tube frame dbl a-arm, rx7 brakes, currently in parts collection/bodywork stages.
Old November 14th 2004, 19:44
Panelfantastic's Avatar
Thick walls always stronger regardless of diameter... but you could go chro-mo and get a lot more strength with thin wall. That's why the racers do it, same diameter as mild steel but a lot thinner gauge, so less weight.
No current VW projects
54 Chevy wagon LS2 AWD
56 Chevy Panel "Lost Cause"
VKG Bastage child
Old November 15th 2004, 01:35
Shadowbug's Avatar
chromo is not for amature welders, it has a very tightly grained structure, inproper welding will cause it to crack, brazing it will make it shatter as it cools.
a few pics of my project
Old November 15th 2004, 08:17
Correct! but if it was a small part, he could farm it out to a pro like I did. Just tryin' to throw out some options.
VKG Bastage child
Old November 15th 2004, 14:16
Shadowbug's Avatar
true
but do remember, chromo breaks where mild steel bends. if that works for you then do it.
Old November 16th 2004, 04:36
Sorry, but the bigger the diameter, the strength increases, so weight for weight a big diameter tube would be stronger.
Also, a round tube is stronger than a square tube. I have the equations if you want...
Rich
