Old March 6th 2005, 21:32
rustbucket's Avatar
Bumper problem
Can I use a 72's bumper bracket with 73 bumpers? They don't seem to fit right. Especially on the front. The holes don't line up. Do I need a different bracket? Rear brackets seem way off too. The holes line up, but then the brackets point in at a "v".
Help!!!!!!
It's YELLOW
Rolling on a daily basis.
Old March 6th 2005, 22:19
How much are they off by? If you can, you could probably weld the hole up and re-drill some in the correct location...I dont know about the back, but I guess you could try the same thing?
VolkSport Kfer Gruppe
www.VolkSport.net
Old March 7th 2005, 03:33
Uber Affe's Avatar
Wink 71,72,73.74+
They all use completeley dif set ups...
Esp. the 74 and up...holes for the shock absorbent bumpers..
73's "look" the same but most use the the standard bumper set up...
71-72 should be identical...so 73 could be the odd man out?
tough question....
Rather than welding up the fenders couldn't you just make a spacer of some sort? I'm adapting my front bumper bolt holes on my '74 to fit a couple of
fog lights and then just meshing over the holes.Try making some bolt-on adaptor plates to attach the bumper brackets to.
Sounds like that'd be easier and cheaper to adapt than messing w/ the fenders...
Also...a bit easier to "reverse" if you mess up...
Just an idea.
Old March 7th 2005, 03:34
Uber Affe's Avatar
oh...
We ARE talking about super beetles right?
I just realised you didn't specify and mine's a 74 Super.
I was talkin 'bout Supers.
