Old December 14th 2004, 00:07
super vw super vw is offline
H&R Triple-C bolts (camber adjustment bolt)
Those who have this (or have seen them in action), how much adjustment have you gotten from them?
Im have about 1/8 POSITIVE camber on my 74 super with Porsche 944 spindles and adjust-a-stuts. I was thinking the use of the H&R triple-c bolts would get my camber back where it should be, safely.
I was going to just "slot" the upper mounting hole on the strut, but i am having mixed opinions on that idea now. i did this mocking up my suspention with stock struts... but with the new ones i got i was wanting to do as much "bolt on" as i could to adjust the camber back.
Also, any one have an opninon on sloting the bolt holes?
Thanks,
Jonathan
Current cars:
-74 Super Beetle
-86 Vanagon Syncro
-64 sunroof bug
-73 thing
Old December 14th 2004, 17:33
Jeza Jeza is offline
Hello Jonathan
I guess your struts don't have a slotted hole with camber adjust?
The golf mk1 and the 944 both have a slotted hole with a cam type bolt.
The H&R bolt is one option is you would prefer not to slot the strut hole. The other is the Topline camber plus kit. This uses an offset steel center to the inner control arm bush so adds much more adjustment.
Cheers
Jeremy
1302 RAt "GermanLook"
Old December 21st 2004, 03:07
Superman
http://www.toplineparts.com/camberplus.html
Old December 21st 2004, 16:16
Topline told me that the camber+ Kit only adds ONE degree of adjustment over stock in each direction, for about $55 bucks.
And the H&R triple-C bolts allow for 3 degrees or adjustment... the h&r bolts are cheaper (around $40).
I think i will try the triple-c bolts first.
Jonathan
Current cars:
-74 Super Beetle
-86 Vanagon Syncro
-64 sunroof bug
-73 thing
Old December 21st 2004, 18:18
Superman
Please let us know how it turns out.
Old December 22nd 2004, 18:11
VWader04's Avatar
VWader04 VWader04 is offline
i used the camber+ kit with the 944/maxx setup and it helped some but did not move the control arm out far enough to remove the positive camber...so...i used the HR TripleC to move the top of the spindle towards the struts to remove more positive camber...have not measured it..yet but its closer than it was..
if your not far off from where you need to be...i would use the hr ...it is also easier/quicker to install and adjust than the camber+
also make sure to use part# tc212 instead of part# tc112 as on the hrsrping website....the website is incorrect...i learned the hard way and had to return/reorder :shrug:
Old January 9th 2005, 14:03
Well I got my 212 triple-c camber bolts (thanks for the warning on the part numbers... I double checked using their measuring guide and the 212 IS the correct one).
I do not have my lower controle arms on at the moment (waiting for some new bushings to come. so i cant see if it works yet. I will let you guys know what's up once I get the front end on the ground.
Later,
Jonathan
Current cars:
-74 Super Beetle
-86 Vanagon Syncro
-64 sunroof bug
-73 thing
Old April 2nd 2005, 14:23
Racelook's Avatar
Racelook Racelook is offline
Can someone please post an pic or an link of that H&R triple C bolts??
Greetings WIebrand
B-Extreme B-Tuning.....
Old April 2nd 2005, 14:27
Racelook's Avatar
I already have found them..
Old April 4th 2005, 04:31
How did you get on Jonathan?
For reference, link is: http://www.hrsprings.com/site/frames/frameproducts.html
Rich
