Old June 18th 2005, 15:52
Rob's Avatar
Rob Rob is offline
Electric Fuel pump placement.
Must an electric fuel pump be mounted lower than the tank ?
I'm just wondering if it will pull the fuel up if it is mounted higher and
there is no fuel in the line yet.
Thanks,
Rob.
Old June 19th 2005, 00:05
Uber Affe's Avatar
Electric fuel pump...
I've seen the placement go in a variety of places.
Some put it up front.
I opted for the pack just left of the coil on the left firewall at about the same height as the coil. I would think that if the pump is mounted a tad higher than the tank...It shouldn't matter that much. Not like you're stickin' it on the roof right?
Old June 19th 2005, 01:01
Lazarus's Avatar
Lazarus Lazarus is offline
depending on the type of pump. i have a holley black and holley specificlly says thier pump (as are most other electric pumps) are designed to push not pull so mount the pump where it can be fed by gravity. thats holley for sure you should check the manufacture of your pump.
Old June 19th 2005, 10:51
Rob's Avatar
Rob Rob is offline
Thanks guys.
It's a pump from a VW rabbit (Golf).
Anybody know where these are located in a Golf ? (Meaning below or above the
tank).
Thx,
Rob.
Old June 19th 2005, 18:40
What year? Is it the CIS feeder pump? If so must were in or near the bottom of the tank.
Old June 20th 2005, 07:06
Rob's Avatar
Rob Rob is offline
Not sure
IIRC it was off an '84 rabbit ? It's the round pump that is mounted in line.
Rob.
