Old June 3rd 2006, 14:44
DORIGTT's Avatar
DORIGTT DORIGTT is offline
How do I clean my dirty arms?
Hello all!
I just purchased a set of aluminum semi-trailing arms for my Ghia and they are DIRTY! What is the best method of cleaning them up so they look new...not polished?
Thanks Pillow for the arms..
Old June 3rd 2006, 22:57
A can of oven cleaner, or engine degreaser, wire brush, and the local car wash is the first step I took. If you have someone with a parts washer then that can do the same thing. Once all the "bulk dirt" is off you can use different types of wire wheels in a hand held drill to clean them up to the finish you want. If you want them to stay clean get some "rattle can" clear coat , and spray a coat or two on them (eastwood company makes a good clear called diamond clear that won't yellow). That way dirt can't stick as easy, and you can hose them off easier .
Old June 4th 2006, 09:46
that's pretty much what i did. degreaser and some elbow grease. (no pun intended)
Old June 4th 2006, 23:24
Bullyboy Bullyboy is offline
Sand or glass bead blasted they look new.
Before
After
Old June 5th 2006, 15:23
DORIGTT's Avatar
DAMN! Mine are definately the before shot.
Are you concerned about grit infiltrating the bearings during the blasting process? I noticed your hubs were still installed....
Old June 5th 2006, 15:45
If I wasn't disassembling them all the way down to the bare bones, I would have taped off the gap.
I am going to replace the bearings later, but I was tired of trying to fit things up and get dirty every time I handled them. I had to try out my recycled junk blast cabinet anyways.
Old June 5th 2006, 20:21
DORIGTT's Avatar
How big of a cabinet did you make for yourself? I've been thinking of just disassembling them once everything works/fits and sending out all of my components which are too big for my bench-mounted blaster to my favorite male-stripper (that's the message the guy leaves me here at work...bastard)
Old June 5th 2006, 20:56
boygenius's Avatar
I always used WD-40 to eliminate most of the grease.
Old June 5th 2006, 21:03
The cabinet is 36Lx25Wx40H. I just used the scrap MDF I had in the garage and thats what the sizes ended up. I lined the inside with white conveyor belting we had at work (headed for the dumpster). I had to buy the blast gun ,gloves, silicone, clamps.
You can expand your table top blaster like I did with mine years ago. We couldn't fit some parts into the cabinet so I built an extension box that just sits on top of the bench mounted cabinet. I removed the glass lid and put a fixed glass into the top box. It has worked good for years like that.
Old June 5th 2006, 21:54
If you don't want to bead blast them, and use wire wheels in drill they look like this.(just for comparison)
Old June 6th 2006, 08:35
I used the wire brush method as well, they came up pretty good. I also used some evil stuff from a chemical company that was a bit like oven cleaner. While washing chemical stuff off, it ran into the bearings, I was going to change them anyway.
Old June 6th 2006, 12:06
I replaced my bearings after cleaning too. Just as a personal rule, i replace all seals and bearings on any used stuff i get.
Old June 7th 2006, 15:15
Pillow's Avatar
Pillow Pillow is offline
Just keeping the rust off for ya
I would just go for Simple Green and wire wheel. It should go quickly.
The bearings are good so I would try and keep them in good shape to reuse.
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old June 7th 2006, 19:07
DORIGTT's Avatar
Hey Adrian,
I'm putting in a new dishwasher so I should freak my wife out and toss one in with her some dishes!
Anyone need a roomate? I'll need a place to stay after that one...
Kinda like putting her on Punk'd!
Last edited by DORIGTT; June 7th 2006 at 19:08. Reason: Using Adrian's real name vs screen name
Old June 8th 2006, 18:00
Pillow's Avatar
LOL
Adrian Pillow
