Old May 3rd 2005, 04:16
vw1303's Avatar
vw1303 vw1303 is offline
4 piston brembos under 15inch wheels
I was test fitting some 4 piston brembos under some 15X8 fuchs on the rear of my 1303. It almost fit! Has anyone ever modified some 4piston calipers to fit under 15inch wheels?
Old June 30th 2005, 06:29
V0LKSWAGENSRULE V0LKSWAGENSRULE is offline
I was wondering the same thing...
It might take 16 inch Fuchs to be able to run the brakes I want
~Dave
______
'55 Ragtop
Needs: TLC
Old June 30th 2005, 07:09
tom'72's Avatar
tom'72 tom'72 is offline
I test fitted some 15" wheels on the 944 turbo (4 pod calipers) I have on my other chassis and that fits.
Old July 8th 2005, 04:15
vw1303's Avatar
Which wheels were they? i think i'm going to make a fixture and turn the outside diameter of the calipers until they fit. I still need to make an adapter for the front calipers as i'm running early 944 spindles.
Old September 1st 2005, 11:47
MdR's Avatar
MdR MdR is offline
I found 15" Fuchs cleared the front Brembos (with a thin spacer) but fouled on the rears when fitted to 944 steel style arms with the ally bearing cap/caliper mount. I also found that 16" Fuchs also fouled on the rears as it was the shape of the inside of the 'windmill' that hit the caliper. I imagine that a thin spacer might help but by then I'd bought a set of 16" 964 Cup 1s.
+44 (0)7812 167547
martinandsonjaATf2sDOTcom
