Old November 13th 2004, 03:24
Bill K.'s Avatar
Bill K. Bill K. is offline
Alignment Advice
My car's ready for alignment and I'd like to hear what you think about my plan for alignment considering my suspension setup. It's a modified street bug (std) with 150 hp. I want a moderately aggressive setup for weekend hill climbs and some autocrossing.
Front alignment plan/questions:
*-2 degrees camber -- are extra eccentric camber adjusters needed?
*2mm toe out -- will this be quick, but not too twitchy?
*extra caster with 1 set of shims -- stable high speed and cornering?
Rear alignment plan/questions:
*-2 degrees camber -- more or less?
*2mm toe in -- want a little oversteer...
FYI, the front has:
*adjustable ball joint beam -- set to neutral height
*2.5" lowered spindles
*Stock 70 bug steering
*GR2's
*20mm Whiteline adjustable sway bar -- set to medium-soft
*+4" wider track
*205/55 Yokahama ES100's on 16x6 Fuchs
*spare tire in well
*chin spoiler (Kamei style) -- coming soon
and rear has:
*24.5mm torsion bars with urethane sping plate bushings
*2.5" lowered with urethane control arm bushings
*GR2's
*24mm Whiteline adjustable sway bar -- set to medium-hard
*+6" wider track
*225/50 Yokahama ES100's on 16x7 Fuchs
*roof spoiler -- coming soon
I plan on tweaking the sway bar stiffness and raising the front a bit to experiment.
Thanks for your advice, Bill
