Old September 27th 2005, 21:14
LOAF's Avatar
LOAF LOAF is offline
How do I route the fr. brake lines???
Making some progress, ran some errands, came back the wife and baby were I sleep so I went to play with the VW..
I am curious as to how folks with the N/A 944 brakes route there brake lines..
I can't seem to utilize the topline bracket.. or at least I may not be doing it right.. Would see best if it was attached to the fender well somewhere instead of the strut..
Also found out that one or both my tie-rods are short.. I think its the passenger side that is short.. can anyone confirm, I think that is what I read.. if so I have my 78's that I will use.. but how the hell do you take the rod off.. that nut is a pain.. mind you i have not gone under with a light to see if there is a cotter pin or something.. for now just PB blasting to soak up the lubercant..
Also pic of the design 90 test fit.. apparently it going to be wider by an inch
Lastly.. A tree branch hit the bug.. everything was well until I was inspecting and I removed some blue painters tape that was holding the hood from when I transported the car... well the tree branch did not hurt the car hood, but I did while removing the tape.. Man I have some good luck.. well have to get that repainted.. I am an Arse..
ALex
also a
