Old October 31st 2005, 07:38
dgluyas's Avatar
dgluyas dgluyas is offline
944 turbo size discs on early mounts?
BIGGER 944 DISCS on Early Arms
Have ; 944T calipers running on thin na rotors at the rear.
Rear is aluminium caliper bracket on standard irs arm.
Am running the thin na disc minus the 21mm spacer.
Want to run thicker turbo size disc at rear.
Is there a disc that is a thick ventillated disc without spacer that would fit at the rear ??
Cheers
David
"Goliath"
Big motor-Big brakes-Big wheels-Big FUN !!!!
Old November 2nd 2005, 08:31
SteveW SteveW is offline
I think you will find a 944T 86 only will work 299mm dia 24mm wide and I think 78mm overall hieght. I just got a pair yesterday. Will be a while before the hubs are back from the coaters before I can confirm.
TIME Never enough - COST Always too much
Old November 2nd 2005, 09:03
I can confirm they fit fine, the offset is correct. I'm using these for my 996 brakes
Rich
