Old March 6th 2010, 14:11
Bill K.'s Avatar
Bill K. Bill K. is offline
412s
Hello again,
Progress on my daily driver '73 412 Coupe has been made over the years and I now have a GL to share.
Most recently, full suspension/brake/wheel upgrade:
* 17 x 7.5 x 55 ET Porsche Cayenne wheels; 195-45 front; 205-50 rear
* 911M front calipers (48mm) with 944 vented rotors (20.4 x 282 mm)
* 20AE Golf rear calipers (38 mm) with 944 vented rotors (20.4 x 290 mm)
* Brake bias valve removed for 1.60:1 brake bias with stock 19mm 412 master cylinder (same as 911)
* Delrin bushings front and rear
* Adjustable front camber and caster
* Lowered front with BMW 318i springs and Koni adjustable struts
* Super Beetle strut bearings and strut brace
* Mazda front spring plate bearings
* Rebuilt steering box
* Modified NOS centerline and ball joints
* Re-sealed fuel tank
The 411/412 has a lot to work with for suspension - struts in front, coil over trailing wishbone in rear - and the wheel wells are huge. Disk brakes in the rear require fabrication.
Before the upgrade, the front had horrible shimmies and was "nose-up", the steering was a bit heavy, and the car had "more motor than tire". Now it's raked, smooth, quick, and stable. I love driving it!
