Old April 14th 2006, 08:08
Chris Percival's Avatar
944S2/968 calipers on 1303
I have a little brake riddle I need to pick your collective brains about. I got some calipers from ebay last year. I didn't know what they where from, but they were cheap. Here they are:
I got some local Porsche specialists to try and ID them. They had some pads to fit them, and from them worked them out to be 944S2 / 968 calipers. I then got some disks for that car, but they don't fit. The disks are 28mm thick but are too thick for the calipers (only by a few mm or so) (a friend had to get them for me, hence why I didn't try them with the calipers before I bought). Turning the disks down would reduce them to below their recomended minimum size. I would still trust them, but would be easier to just get ones to fit. So anyone have any idea what these calipers might be? Could they be rears? They would need to fit late 944 hubs.
Chris
Old April 14th 2006, 08:38
Some more info: The calipers don't have any Porsche part numbers on them, only brembo ones. If anyone could look them up maybe? The disks I have are the correct diameter as the pads fit them perfectly.
Old April 14th 2006, 11:35
speedy's Avatar
speedy speedy is offline
chriss could you not just have 1mm taken off each pad , there is plenty on them 1mm is only is only a small amount of wear
cheers jon
woop woop
67 2276 turbo
64 ghia 1776
zx7rr
Old April 14th 2006, 16:09
No, they don't actually fit in the calipers...
Old April 19th 2006, 07:14
Does anyone know what callipers these might be, or what discs might fit them?
Old April 19th 2006, 17:14
Mikey's Avatar
Mikey Mikey is offline
They look like '95-'98 993 rear calipers.
I just bought a full set for my Ghia. As for the disk, I'm not sure. I've got 944 rear caliper brackets, and rear hubs. I'm just going to go with the stock rear 993 disk. Also, the calipers I have Do fit the 944 brackets.
Hope that helps.
*I snapped a few pictures tonight of the 993 rear caliper and the 944 bracket together. I forgot to mention the bleeders and the crossover tube will have to be switched. Originaly the calipers were mounted in front of the axles.
Mike
'04 R32 Tornado Red
Old May 3rd 2006, 21:05
tommi_nylund tommi_nylund is offline
Dear Chris.
Your callipers look 928GTS / M030 951 rear-callipers in my eyes.....
You can use any Porsche rear disk below 300-305mm and 24mm thick with them....I think..
But I´m not sure which is best choice to get handbrakes work right. I´ve been searching information if I can use 951 rear disk (951.352.041.01) with n/a handbrake stuff and n/a control arms etc...?? And I think it would be possible?!?
You cannot use any front disks because they don´t have drum area to handbrake. You will need 180mm diameter inside the disk hub to get handbrake assembly fitted in.
993 352 041 02 Disks will be fine too, I think.
I tested my callipers (928 GTS) with n/a a-series 944 original rear calliper carrier, steel arm and n/a 20.5mm disk and everything seem to be ookay. Maybe it is good to use 1.5mm spacers between the brake pad and pistons though.
Old May 4th 2006, 02:17
I don't know about rear disks, as I will be using this setup as front disks. For the rear of my bug I am using a kit which uses 914 discs and MK4 Golf rear calipers..
Old May 4th 2006, 21:17
Ookay, my mistake!
Front you can use that 993 disk fine I think.
And those 928/951 rear callipers should be fine with G4 rear callipers...
Old May 4th 2006, 21:47
Mikey's Avatar
What's the differance, if any, from the 993 rear calipers to the 951/928's???
Mike
'04 R32 Tornado Red
Old May 5th 2006, 02:18
Well I now have the 993 rear discs, and they look perfect. They even come crossdrilled..
Old May 10th 2006, 23:08
flat flat is offline
I'm a little late in this conversation, but...
All 944T rear calipers are the same. The 993 rears are alittle prettier (smooth font), but they are the same as far as piston sizes and mounting ears etc..
Chris, try getting your hands on a boxster frontrotor, and then use that caliper you have in the front. I was mocking up up a similar setup, and I think it would work very well. On paper, it's about 12% more brake torque that a karmann ghia setup, with only 5% or so more fluid requirement. So it would work well with the stock master cylinder. Since the P-car caliper is stiffer than vw parts, the increase in brake performance will probably be more than what the numers show (ie 12%). And ofcourse you have a vented rotor with greater heat capacity and dissapation. Also, since it's a 24mm rotor, you save alot of weigh when compared to a 28mm setup...personally I think most that for most guys, the big-brake setups with 28mm and thicker rotors on a bug are a waste...they weigh a ton. (opps..there goes my business out the door......)
Easy,
www.vdubengineering.com
Old May 11th 2006, 02:18
Thats exactly what I am doing, these calipers and disks will be for the front. I have a kit for the rear utilising Mk4 Golf rear calipers, and 914 disks. Your right about the weight saving, its all working out pretty good.
Old May 12th 2006, 05:20
Jim Hunter Jim Hunter is offline
Smile
Hello Chris,
The 94 inside the calipers is the production year.
Easy way to tell if they are front or rear :
Look the pistons 4 same diameter pistons = rear
2 pair of pistons (1 pair per side) = front
Also if I see correctly the script "Porsche" is decal applied not cast of the caliper correct ? These is much more 944S2/968 rear calipers.
FYI : Marco with TBO WBX bug has used 4 rear 996 calipers all around with success.
Good luck
Jim Hunter
74 1303 (GL project) *SOLD*
73 1303 (GL project II)
(VW T3s for sale.Panels, 2wd and Syncros)
