Old August 4th 2006, 17:12
pantswagen pantswagen is offline
type 4 1700cc engine
comes with a 210 flywheel and clutch
-it looks like it has a plate in it for type 1 shaft support
pistons and barrels rings all look good -domed high comp
-chambers in heads and the valves don't tho!!
has short early j tubes
-i cut the tower off havn't scooped it down tho
has a bit of float
can throw in a 901 fan 'ring'
still has the early small threaded rockers -off
-story is i went to get a 091 box, and had to buy the engine - which turned out to have fresh heads and seems rebuilt -new pump -push rod tubes etc
-but its a vanagon head lump -and also i dont need the 210, as i'm 091
-and i have a complete fan unit, so
-the 1700cc can go
£200 quid cheap!!!!!!!!!
collection only tho
-london
0774 858 2044 -please don't expect too much
-will swap for a pair of 40's with inlets? -give you 48mm inlets???
