Old May 12th 2007, 12:26
Its almost in !
Hopefully by Sunday evening, this engine will be installed ... just have the valvetrain geometry to do and then install the cooling system and reconnect the electronics.
Almost there .....
I'll be at the June meet with the bug ... guaranteed.
Old May 12th 2007, 20:36
gonebuggy's Avatar
Lookin good man! what are the specs on the beast?
So this could be THREE maybe FOUR! bugs at the next meet? If you have yours done, and pete and I get mine done.... Chris is WAAAAAAY ahead of the game and had his at the last one.
Cheers
1970 Bug
2110cc. ???Whp, ???Ft/Lbs
Old May 13th 2007, 09:09
Thanks.
Specs are :
2.0 T4 with RAT custom cam, HAM 42x38 turbo heads, ceramic lifters, dry sump, MS injection with 599cc/min injectors, PWR air to water, 911 cooling, datalogger, and a VF39 turbo from a 2005 STI.
The parts for the 2.4L are sitting on the work bench, just waiting for the custom JE's and LN Engineering 98mm V2 Nickies to finish testing. I hope to start assembling this motor by the end of this year.
Lets get those aircooled's out of the garage and onto the streets !
Old May 15th 2007, 17:26
petevw's Avatar
petevw petevw is offline
Sandeep, sounds like its coming together well.
Looking forward to seeing some bugs out at the June meet.
'72 super
'65 bus
'52 split
Old May 15th 2007, 17:28
chug_A_bug's Avatar
very Nice buddy can't wait to see all the bugs
74 Std. GL
08 Vw rabbit
18 WR250R
07 Chevy 3500 Dually
Old May 16th 2007, 10:19
Got the motor in and will start wiring it up tonight.
Does anybody have any rocker arm base shims that fit between the head and rocker shaft assembly ? I'm thinking T1/T4 are the same except I need 8 for the T4 as the T1 only has 4. Rocker geometry is a bit off and I want to do the best I can.
Its a little too late to order some now ... I want to fire this engine up on the weekend
Old May 16th 2007, 17:42
petevw's Avatar
I've got a couple sets of T1 rocker shims. Sets of 4. I could make them out of shim stock if you know the thickness you need.
'72 super
'65 bus
'52 split
Old May 16th 2007, 18:01
gonebuggy's Avatar
i have a couple leftover myself, and i could also make you some. Let me know
1970 Bug
Old May 17th 2007, 08:55
Thanks guys.
Pete,
Can you tell me how thick they are ? I am not sure on the size I need but I'm thinking I could start with any thickness.
I'll need 8, let me know.
Old May 23rd 2007, 09:29
Looks like I sorted out the rocker arm geometry without any shims. I installed the cooling system and wired up the car last night.
Tonight I have to install the injectors and check the fuel system before starting it up .. hopefully on the weekend.
Hope to be on the road and driving for June 1st
Old May 23rd 2007, 17:27
petevw's Avatar
Is it running yet?
Your cheating. Where is the apron?
'72 super
'65 bus
'52 split
Old May 23rd 2007, 18:43
big daddy's Avatar
big daddy big daddy is offline
Maaaan! Almost
Looking good, cant wait to see it in and running.
Big Daddy/ VW EGO
Lets Gooooo
Old May 23rd 2007, 21:39
Hope to have it running for the weekend. Just received some thermocouples so now have to drill and tap the bottom of the DS tank to get an accurate oil temp reading.
I've got an Innovative Motorsport LMA-3 and TC4 to hook up still ... they both talk to the megasquirt so I can get some kick a$$ datalogs ... going to tuning this motor on the EDGE !!!
Old June 3rd 2007, 12:02
Well,
The motor fired up on the first few cranks It sounds meaner than the original 2.0 so I'm going to have to evaluate it on the road because I have no muffler (no room).
I'm tuning the motor with the laptop right now ... on track for a road test next weekend
Old June 3rd 2007, 13:05
gonebuggy's Avatar
DAMN! that looks sexy! i almost tipped the keyboard right off my lap, if you know what i mean
good work bro!
1970 Bug
