Old June 23rd 2006, 17:10
hugovw1976's Avatar
hugovw1976 hugovw1976 is offline
Finally the chasis it's done
Finally the chasis it's done.
The primer it's temporary just for the rust.
VW 1976
Old June 23rd 2006, 17:11
hugovw1976's Avatar
VW 1976
Old June 23rd 2006, 18:24
junkyard oval junkyard oval is offline
YAAAAAAHOOOOOOOOO
Looking good. That is a very nice job. Work well done. I know you are looking forward to having it all together and back on the street.
Ernie
Old June 24th 2006, 02:01
LLVWGL LLVWGL is offline
I can't wait to see this project on the road, Keep up the good work!
Old June 24th 2006, 05:29
Looking good!
One question though, why did you use a single upright section at the very front? It would be a LOT stronger if you used a vertical tube at each front corner, the front suspension would be working from a more rigid frame...
Rich
Old June 24th 2006, 07:52
DORIGTT's Avatar
DORIGTT DORIGTT is offline
Bravo!:agree:
Old June 24th 2006, 10:32
hugovw1976's Avatar
Originally Posted by ricola
Looking good!
Rich
good observation.
Thath is temporary becose I don't have the stering yet and I need it to know here it's the rigth location.
VW 1976
Old June 24th 2006, 12:59
EvilAngel's Avatar
EvilAngel EvilAngel is offline
Congrats for the good work Hugo, I just realized you also posted here. Im into german look too, so we'll see around here.
:agree:
________________________
1990 Mex-Spec GL Bug "The Blue Flame":
Engine: Planning Stage
Transmission: Planning Stage
Suspension: Front: 3/4 swaybar w/UrethaneBushings, Dropped Spindles. Rear:CB Camber Compensator. Lowered 2 splines
Brakes: Front Brakes: 280mm solid rotors, two pot calipers. Rear: 280mm solid rotors, 1 pot calipers w/ebrake
Old June 24th 2006, 13:09
Bad bug's Avatar
Bad bug Bad bug is offline
Since this engine is not aircooled where did you put the radiator, can't seem to make out where that would fit.
Old July 27th 2007, 16:44
loveofbugs loveofbugs is offline
beautiful chassis
To hugovw1976:
I love what you have done with your chassis. Can you get back to me with some info on your modifications? Would you actually consider building another and selling it?
Loveofbugs
email
ttullius@sbcglobal.net
Old July 27th 2007, 18:45
Bad bug's Avatar
Good day Hugo,
I have asked this question before and i was always shown chassis like this. But i will post that question again. Can a tubular chassis be made so as to fit a vw beetle body over it retaining the original position of the engine. The upper sections of your chassis wouldn't be in the design this chassis would resemble the original chassis but only be tubular.
Old July 30th 2007, 17:07
hugovw1976's Avatar
In the spare tire location.
VW 1976
Old July 30th 2007, 17:10
hugovw1976's Avatar
Originally Posted by loveofbugs View Post
To hugovw1976:
Loveofbugs
email
I don't think so, its to much money and work.
VW 1976
Old July 30th 2007, 17:12
hugovw1976's Avatar
Good day Hugo,
I think it's possible.
VW 1976
Old July 30th 2007, 22:29
Bad bug's Avatar
I was looking at a 911 targa here in jamaica and i noticed that it didn't have any frame horns like the beetle. The engine and gearbox matting arrangement was similar to the type3. If a rear cage could be built along with the idea i gave you hugo and still allow the beetle body to mate to this new chassis that would be wonderful. The car would have a further weight reduction.
