Old May 11th 2010, 23:22
seangfy seangfy is offline
subaru powerd 1303
ive been on hear for a wile now and i think i finaly have some pics and a good list of stuff ive done/doing so hear it is.
the car started out as a 71 super but the body was nothing but filler and rust
a freind of my had a 73 body with a bit less rust on it so we swap them my pan was already modded for the 901 trans
hears some pics of the 911 shifter mod
911/914 transmission
setting up the dash to run 05 wrx gauge cluster
and last but not least the power plant 2.0 turbo subaru
Old May 12th 2010, 01:17
Very cool, keep us updated!
Old May 12th 2010, 07:50
evilC's Avatar
evilC evilC is offline
It looks interesting but I would check your fuel gauge out though!
Old May 12th 2010, 11:30
jmd's Avatar
jmd jmd is offline
Into it... Can you tell me where you got that really nice base for your shifter?
Also, what exhaust and ECU are you running?
I can't wait to get back to working on my build... thanks for the pics.
Old May 12th 2010, 12:27
The base for the shifter was the center section from a 914 found a wreck one and cut it out and trimed it down.
Old May 12th 2010, 14:28
Looks like you're off to a good start. I presume you know your heads are going to stick out of the rear bodywork though with the trans in that position?
Old May 12th 2010, 18:15
jakriz jakriz is offline
G'day
I love the wrx dash cluster!
Did u put the aftermarket headers on the engine. I have found that they hang alot lower than the standard headers & u also lose bottom end torque. Most of the big power wrx's here in Oz still run the standard headers, just ported with a bigger cross over pipe between each bank. I have done this to mine & it made boost come on earlier & smoother.
hope this helps
regards
Jak
Maltese Falcon Racing
http://www.superbeetlesonly.com/foru...y&cmd=sc&cat=6
Old May 12th 2010, 19:27
I'm a little worried about the how low the header hangs down the only reason i have that one is a Friend had it laying around. The engine was originally a twin turbo motor so i ditched the stock twin turbo stuff Ive heard nothing but bad things about trying to get that to work
As for the the heads sticking out i might have to remake my transmission mounts to get it to go back a little bit more so i can try to squeeze the timing covers im waiting to get my adapter kit from Kennedy to start test fitting i set the gear box up for using a type 4 engine first than changed my mind and decided to go Subaru.
jmd I'm planing on running a magasquirt ecu Ive emailed the guys at diyautotune.com he gave me a list of the things i will need to order to work with the turbo and the coil on plug subie set up about $600 or so for the set up
thanks for all the comments guys
Old May 12th 2010, 20:58
Bug@5speed(US)'s Avatar
Sean,
Got a Bugat5speed sump in stock if you happen to have clearance issue.. not a bad time to take advantage of the weak euro.. Just a thought
VR
Alex Olaverri
Email: Bugat5speed@yahoo.com
Tele: 973 204-5463
Old May 12th 2010, 21:09
whats is it going for will need a sump soon need to get my ecu orderd first if you still have it when im ready i check with you thanks for the post
Old May 12th 2010, 22:34
Scotts73SB's Avatar
Good to finally see pics of the car and the progress. Lookin good so far.
Nice seats
Old May 17th 2010, 01:07
did a little more work on the body today removed the rear apron
Old May 21st 2010, 23:51
little more work done and i have some new parts
my kennedy adapter plate going to do some test fitting this weekend if the weather holds out to see how much i will need to move the transmission or cut the body
bought my radiator and started cutting and test fitting a bit
going to sit it down a little lower and a littler ferther forward just need to cut a bit more
Old May 22nd 2010, 21:21
Joel's Avatar
Joel Joel is offline
the adapter plate faces the otherway around
spin it so that side is facing the trans
Old May 23rd 2010, 20:59
good call buggin havent had much time to mess with the adapter yet so thats good to know
