Old December 7th 2002, 15:15
paul_f's Avatar
paul_f paul_f is offline
944 Brake disc torque settings
Anyone know what torque I should be doing the bolts up to on the early 944 front discs?
Cheers
Paul
Old December 8th 2002, 00:28
chigger chigger is offline
Which bolts? Sorry but I am confused.
Old December 8th 2002, 06:57
paul_f's Avatar
On the early front disc brakes, the disc is held to the hub by 5 bolts. Its these bolts.
Old December 10th 2002, 01:45
The torque spec is dependent on the size and hardness of the bolt. For some reason metric bolts are quite low. I believe the Bently manual lists the max and min torques for each size bolt. My manual is out on loan so you might want to run a search on the internet. Make sure the threads are clean and for anything concerning the moving parts of the chassis I use blue locktite. You will never get it apart again if you use red locktite. Hope it helps.
Old December 10th 2002, 06:27
paul_f's Avatar
Thanks for that - I was worried about not doing them tight enough, but I know what happens if you do them up to tight.
Its quite a strange design, as every other set of disc brakes I have worked on has had the wheel stud or wheel bolt also going through the disc.
Paul
Old December 19th 2002, 20:45
Michael Ghia's Avatar
The bolts in question are standard 8.8strength M8 bolts.
18lbft on each.
MG
Old December 20th 2002, 04:39
paul_f's Avatar
Thanks Mike!
