Old June 1st 2009, 02:01
graham's Avatar
graham graham is offline
Jake Raby 2276 with EFI
For Sale 2276 fuel injected type 4 engine.... 173 bhp
Engine spec
Engine Case- 022 type 4
Bearings -Original VW Klolbenschmidt
Crankshaft-78.4- Balanced and Counterweighted
Connecting rods-H beam 5.400 length
Camshaft- Web Cam ,custom grind
Lifters L N Engineering Ceramic
Cylinder and piston assemblies 96 mm cast iron with
Hypereuctectic pistons 96 mm
Cylinder heads -New castings full stage II port and polish with hand shaped chambers with balanced chamber volumes
Pushrods -Manton Chronoly ,cut to length
Rocker arms VW forged units, 1.3:1 ratio solid spacers
Valves-stainless steel made by Marnel
Valve adjusters - 911 swivel feet
Oil pump- Modified Type 1-/Shadeck 30 mm gears blueprinted
Ignition-Mallory Unilite distributor
Ignition cable etc- Bosch
Cooloing system DTM Stage IV
Flywheel- 210 mm with Raby Aircooled Technology conversion
flywheel
Pressure plate- Sachs new
Clutch Disk- new Sachs
Rabys Fully programmable EFI with dual twin throttle bodies
call or email please 07803 971 147 UK
gee dub
Old June 1st 2009, 08:34
Panelfantastic's Avatar
You might throw out a asking price just to keep people clear on what this is. This is a best-of-the-best, top of the line engine. There is usually a waiting list to have one done.
Also, is it still in the states? or have you already got it home?
Just trying to help you get the right phone calls.
Jeff-
No current VW projects
54 Chevy wagon LS2 AWD
56 Chevy Panel "Lost Cause"
VKG Bastage child
