Old November 16th 2014, 20:02
effvee effvee is offline
Dell 40's d0wn draft
Hi, does anyone have a chart on the Dell DHRL downdraft 40 Emulsion tubes that are offered?
Old November 18th 2014, 12:33
Dhla are side draft, down draft are DRLA, there are generally only 3 emulsion tube types for DRLA, common most are 9164 .1 .2 or.3, the .1 is common to Alphas, the .2 for VW, .3 I've seen only rarely And is supposedly a mid range tube, say for off road use, DHLA have more tubes available, and I recon would ultimately find more power on VW motors, obviously, packaging is a problem but it could be done for a race car, the Formula Vee champion this year was a side drought motor. I've not come accross any VW motor that a .2 tube didn't work we'll, 1600cc up to 2.5, with max RPM Ranging from 5.500, up to 7,500.
Regards, Spanner.
Old November 19th 2014, 09:56
Good morning, yes ours is the 9164.2. Ok, that float setting is very temperamental, spec's state 5-6 mm closed and 12mm drop. So it's back to the drawing board. I'll set the fuel pressure to 2.5
