(Repost) G50/01 Teardown Info
Ended up having my G50 serviced/shortened by CMS. Here is the info I used to initially tear it down:
Here are the references I used: Wally's G50 Post on Pelican Parts Post on Impact Bumpers Removed the cover: ![]() Air impact to remove the 40mm and 19mm?: ![]() Removed gear and slider: ![]() Used a Proto Puller after grinding off most of the arm material to fit under the gears: ![]() ![]() ![]() See some worn/flat teeth on the thin black ring attached to the gear, but they don't appear to be broken? ![]() Pulled the case off: ![]() ![]() Main Gear assembly: ![]() Removed the m8 nuts holding the assembly to the case: ![]() ![]() Removed Diff: ![]() ![]() ![]() Working on a long socket to remove the input shaft from the gear assembly:
