Old January 7th 2004, 20:42
FLAT4MATT FLAT4MATT is offline
Weber 40IDF 30mins dyno use only
I'm selling a pair of weber 40 IDF carbs that are BRAND NEW appart for about 30minutes use on a dyno. No linkage, filters, manifolds. The carbs will also come with high quality machined alloy velocity stacks (ram pipes) which are about £12-£13 each (thats £44-£48 for the set...)
Remeber these are new so no need to replace anything, ready to run straight away no worries.
Want what i paid a month ago £300 not used since then so not really open to offers...
Look at it this way... If you were looking to buy a new weber set up this could be a way of saving some cash
*£300 for the carbs and 40mm velocity stacks (40s dont come with stacks fitted)
*£150 gets a brand new CB Hex linkage with offset manifolds and K&N style filters from VWSPEEDSHOP
Thats £450 for a 40 IDF set up, a saving of £115 over the cheapest in the UK, not taking the £45 stacks into consideration, which would make it a saving of nearer £160
THESE CARBS HAVE ONLY HAD 30 MINUTES LIGHT USE ON A DYNO AND ARE MINT! LIKE NEW ONLY BETTER DUE TO THE STACKS...
Only reason for selling is that i'm now going to be running 45 dellortos
£300 for carbs and velocity stacks or £270 for carbs without... i'll even have them jetted to whatever spec you want before you pick them up...
Can't say fairer than that...
New pics of my bug at...
www.geocities.com/longdonguk
