Old July 27th 2004, 22:09
oasis's Avatar
oasis oasis is offline
Topline choices
Boy, I didn't know what to call this thread. I'm not even sure if this should be here, in "Brakes" or in "Tires." I guess my biggest questions are suspension related, so here goes ...
I have a stock 1971 1302 (pictures forthcoming if the weather ever improves). I want disc brakes. I want to use the BBS RX-II wheels which they make for VW's Golf, Jetta and New Beetle. That means I want a 5x100 bolt pattern. I know there are European options and I know I will eventually buy European in other aftermarket areas, but I want to stay on the home soil for this much of it.
I prefer to avoid Porsche items. I really don't know why I feel this way. I guess I want to build a Super Beetle the way Volkswagen should have -- in my view, of course -- and would have if production continued to 2004.
The wheels (still unpurchased) are 16x6½ et42. Jon at Topline thinks I should go with:
- their Sports+ springs,
- the smallest tire I can find for the front (whatever size that might be),
- the tire closest to 25" in diameter regardless of width for the rear (whatever size that might be),
- oil-type shocks for the front,
- gas-type shocks for the rear (mine actually already has these),
- their 7/8" front sway bar, and
- their urethane kit for the front.
He believes no further modifications would be necessary and this would lower the car by roughly an inch. (I assume the inch refers to the front.)
Reviewing the Topline site, I also noticed MaXX struts and Adjust-A-Struts. The minimum amount of lowering with the MaXX is 2.5". The picture of their green 1302 sure looks nice but I've seen two posts alluding to the rough ride becoming an acquired taste. While the AASs can also lower the 1302 to 5", it has a minimum of 1.5".
As I am typing, I am remebering some solid advice about doing things as incremental as possible. So, I will probably go ahead with Topline's suggestions unless others pose other possibilities.
At the same time I am curious what people think of the MaXX and AAS options from personal experience if I should want a more aggressive stance. Would I have to make any changes or additions if I choose one or the other later down the road. I know Kerscher enjoys a solid reputation as well but it seems through my search patterns that no one has experienced both to give a compare and contrast.
Any and all last moment input is greatly appreciated.
Old July 28th 2004, 03:05
My 1302 is currently running Maxx's and you are correct, it is a aquired taste for feeling every bump in the road, but they work good in the corners. Before the Maxx's I ran AAS's wit oil cartriges, and they worked good as well. I have zero experience with sport+ springs but if you use them with AAS you'll be 2.5" minimum lower in the front.
Are you considering disc's in the rear as well? Most of the modern sportier cars have discs on all 4 corners.
Sounds like John is pointing you in the right direction, you might want to invest in a new idler arm bushing as well, I used the fancy bronze one(should last longer then the rubber one). It will feel like a new car.
Old July 28th 2004, 08:18
oasis's Avatar
While perhaps unnecessary, I have decided I'd feel better with four-wheel discs -- especially all coming from the same source. I will also present your suggestion about the idler arm bushings to Jon.
I'm curious, though. Why did you swap out the AASs for the MaXX struts?
Old July 28th 2004, 08:23
I'm running the MaxxStruts too and I like them. They give you a little more room in the front for wide wheel/tires. I have them at the first drop setting and it is just right for my car. :agree:
Old July 28th 2004, 08:40
oasis's Avatar
NO H2O, are you running 17s like the display 1302 at Topline? Did you go from stock to Maxx, or did you have other mods along the way first? Are some roads a bit jarring to drive?
NO H2O and Supa Ninja, are your rears ... you know, each of your car's rear -- lowered? If so, how and by how much?
Old July 28th 2004, 08:56
I'm running 16x6 C2's with 205/55/16 rear and 195/50/16 in front. The ride is firm in the corners but it dosn't beat you to death all day so you can drive it without a kidney belt. I think the MaxxStrut uses a Rabbit strut cartrige that you can upgrade later if you want. My rear is lowered a little but still clears my Phat boy muffler, well most of the time it clears.
Mine is a 72 1302.
Old July 30th 2004, 08:48
I have to disagree with Joe on the ride of the MaxxStuts. Once you lower the front and fill the fenders full of wheel and rubber, you only have 2 inches or less of travel left before you have rubber to fender contact. Couple that with the 17 inch 40 series tires that he was running and the ride will be stiff on either strut. I think the maxxStrut manages the small amount of travel very well. I am running a 50 series 16 inch tire and have driven the car on several long trips and lots of in town driving and have no complaints with the ride. It's no Lincolin Town Car but that isn't what we are after either. You could put 40 series tires on a Lincolin Town car and it will ride like a lumber wagon. If I were building a track car I would spring for the Kerschers just for the adjustability, but for a street car that handles well, I like the MaxxStruts. John has done a great job with them. I think that most people that have them or have tried them will tell you the same thing.
Old July 30th 2004, 10:43
vujade's Avatar
vujade vujade is offline
I just think that John used to stiff a spring for them seeing as they are only a single rate. they should have been a little softer (not too soft though), or like Dave said they would bottom out or rub tires.
WinterJam 2010
Old July 31st 2004, 09:36
oasis's Avatar
I feel as though I am chasing my metaphoric tail ... which I thought would end once I finally purchased a car. One person's "too stiff" may equal another's "just right." Nevertheless, this is exactly the spirited, yet constructive, responses I was hoping to get to help me make my decision. I just wish I could drive or ride in a modified Super to get another personal point-of-reference besides stock (from when buying).
Some random responses and queries ... I am waiting for an e-mail response from VDubCustoms. The VW 5-100 bolt pattern is what I'm wed to more than VW brakes, but that intrigues me. It's not clear from their site if they can/will do rear discs and if so, whether I would have use of the hand brake.
I may call them on Monday if I haven't yet received a response. (Some companies, local and otherwise, suck at responding.) Later today, I will try to find Kerscher's and CSP's Web sites. Seems to me I've been at both before. I will call Machine 7 on Monday as well.
Do brake kits need other ancillary items? ... like hoses, discs, master cylinders, etc.? I have never asked before but VDubCustoms say what's not included and it makes me wonder that I'm supposed to assume something I'm not savvy enough to assume.
Okay, Kerscher uses Eibach and Koni as mentioned by vujade. What's stopping me from going to a local shop and getting those individually (plus whatever else I need)?
And since this has developed into a Kerscher-MaXX compare-and-contrast-fest, how much more of a bullet would I be biting if I go Kerscher? (I realize this is most likely a ballpark figure if anyone knows.)
Thanks for all of the responses so far, and upcoming. Whatever I end up with is what I will live with until the project reaches its conceptual end. Then and only then will I go back and tinker as I will be in the tinkering stage anyway.
Old July 31st 2004, 11:10
Talking
Buying the right car is only the begining, roll your sleeves up cause the real work is going to begin.
Old July 31st 2004, 15:23
vujade's Avatar
the kerschers are gonna run you close to $700 vs $450 for the Maxxs
WinterJam 2010
Old August 4th 2004, 22:06
Superman
No one realizes, or has posted, that the choice of wheels and tires has a lot to do with the ride quality. The MaXX springs are just 10% over the stock rate, those 40 series tires on wide 17" wheels contribute a lot to the ride.
Old August 5th 2004, 04:45
oasis's Avatar
I kind of thought that might be the case. That's part of the reason I like the BBS wheels I'm kind of wedded to. They're modern, lightweight and being 16s, I will still have some sidewall as a cushion.
One helpful chap suggested 205/45s on the front and 225/50s on the back. At that suggestion, there will be some harshness. Some harshness was expected as a trade-off for superior handling but I am not trying to push the superior handling envelope.
I'm afraid I don't know what "10% over the stock rate" means. Is there some non-subjective measuring tool when it comes to springs and struts?
And let me ask another basic question. What are the functional differences between springs and struts? I never really gave it a thought before.
Old August 6th 2004, 00:16
I don't know about that 10% either. I just know with adjust a drops and stock springs when i bounced on my bumper(i'm only 170 lbs) the control arms bounced off the ground. With the Maxx's i'm lucky to get 1/2" of movement. Ride-wise a lil on the stiff side but do able for a street car, and they more then make up for the lil dicomfort in the twisties.
Nick
