Old October 31st 2004, 23:28
73notch's Avatar
73notch 73notch is offline
High perf and stock type 4 engine parts 2270
:-( my entire t4 engine lot is up for sale. hopefully ill be able to do it later on.
help me out.
heres what i have
-78.4mm DPR stroker crank with type 1 journals(stock rod journals, 10 on mains)-400
-96mm piston and cylinders(already machined by rimco to proper specs) and hasting rings-350
-H-Beam Rods, type 1 5.395"-300
-Webcam 163/86b broke in on dyno only.-75
-HEADS
-1.7l heads, recently rebuilt-100
-1.8 heads-75
-2.0 heads oval ports, non porsche-75
-New Johnson lifters
-2L crank and rods-100
-1.8L crank and rodsx2-50 each
-2 cases in good condition, 1 is polished on top, the other isnt. ?
- 1.7 p+c set, barely used, couple broken fins-40
-new 210mm clutch-10
-bus 210mm flywheel-40
-210mm new pressure plate-30
-porsche 914 flywheel-50
-fuel injection system off of 1.8l engine-100
-used 1.8l p+c set-30
-3 94mm cylinders-30
-stock aluminum pushrods-15
-valve covers-10
-windage tray-10
-2 fan shrouds w/ alternators-40 each
-CB carb manifolds-35
-rebuilt 42 DCNF carbs-250
-DCNF t1 manifolds-30
-DCNF t4 Shortie manifolds(very short, good if you are putting in a type 3)-50
-Both of Jakes Bug Me videos, How to rebuild your T4(VHS)-20, and DTM install.(DVD)-20
Email me with offers.
Shipping not included in price
After a week, they are going on ebay
If you need something not on the list, ask me, I might have it.
pics are http://www.cardomain.com/memberpage/426700/2
www.subynotch.com
