Old October 7th 2002, 21:39
Eduardo Eduardo is offline
VW Type 1 to 901 trans needed parts ?
HI,
Please help me with this.
I´m building a 550 spyder with 901 trans
I already have the 901- 73-76 914 sideshifter trans with complete linkage.
I supose that I will need the following parts to can acoplate this engine to the trans:
Flywheel- 912 (every model with stock but optional 901 trans every year. Except the 76 e model (type 4)and all the previous 4 forward speed trans (356) 902.
starter- 911-912-914 also the new one 1.5 hp can fit.
Pressure plate - 901-911-912(901)-914
cluth (911 6 springs or 914 4 spring ) I wil go to 6.
trow out bearing- any of the 901 trans models ? i´m not sure ?
I believe is everything ?
Somebody told me that I can adapt a 914 type 4 flywheel to my crank, but I believe that a bolt in 912 is ok.
Except because a used but good condition 914 flyweel is about $ 35 and the 912 $ 150 (new one are expnesive ! )
What about the shafts ?
let me know
regards
550 spyder project 2180cc and 901 sideshifter trans.
