Old February 25th 2005, 09:42
headlight switch
for those not using a stock headlight switch, i would like to see some pics and get info on what you are using. through bad planning mine is under my dash (that was the good planning) and nestled in between and behind two VDO gauges (the bad planning since i didn't expect to have under the dash gauges). there just isn't enough room to have the knob on the shaft. i need to switch to a toggle or something.
interested in info on:
  • style
  • make
  • source
  • wiring converstion from stock
