Old August 22nd 2005, 19:28
T1 with 915 trans.
Is it possible to fit a T1 engine into a 915 or 914 5speed gearbox without any modification?
T4 2666 1303s
Old August 23rd 2005, 17:44
Rouser's Avatar
Rouser Rouser is offline
No ...
All Porsche trannies will require extensive modifications; some more than others.
Rouser!
Old August 25th 2005, 06:06
MdR's Avatar
MdR MdR is offline
The engine will bolt straight up to the gearbox. You will need a different flywheel and clutch to enable the starter motor to engage and get drive from the crank to the first motion shaft. Kennedy Engineering can help.
You will also need to check out the clutch release mechanism.
The 914/4 mechanism will work as factory with the priviso that the release arm is in a different place to the T1 'box so you'll need to re-route the clutch cable.
I have no personal experience in making a 915 clutch work in a T1.
Here's one solution on Russ Fellow's car
Both types of gearbox will need the T1 chassis & body modifying. The 914/4 gearbox needs the diff. flipping (or you'll get 5 reverse and 1 forward!) plus a 911 style frount nose cone & gear selector rod.
But apart from that it's easy (I've managed it... )
+44 (0)7812 167547
martinandsonjaATf2sDOTcom
Old November 1st 2005, 17:05
skywalker
SilverBullet,
Did you get any futher with assembling a 915 or 914 gearbox into a splitbus?
