Old December 9th 2005, 12:33
joetech joetech is offline
best way to lower the SuperBeetle?
Hi gang, my first post here. Happy to have found a VW site just for my kind of Beetle!
I'm starting to think about disc breaks for the front-end, I already have most of the stock Ghia parts to do this (I'll explore the more sophisticated disc break systems later in life, going 'stock' for now). But since I'm "going-in" to the front like this, lowering the car is also something I'd like to do...
My question:
What's the best way to lower a SuperBeetle? Spindles or suspension (struts)?
If it's spindles, needless to say I'll have to buy aftermarket. But if it's struts, I have a 1973 Super, and I'm not sure just yet if it's an early or late model (gotta check my vin# and get back to this) so I understand that the struts differ on this car...
Cheers,
Joe.
1973 Super Beetle convertible
San Francisco, CA
Old December 9th 2005, 13:20
LOAF's Avatar
LOAF LOAF is offline
My two cents..
Topline, doesn't matter if early or late.. they have both applications..
Early has three bolts that hold the ball joint.. while the late is a two bolt set up.. kinda like what is seen on most new cars..
also a
Old December 9th 2005, 13:39
So it's struts, not drop-spindles then?
Why one over the other?
Cheers,
Joe.
Old December 9th 2005, 15:38
madpballer232 madpballer232 is offline
idk maybe im just dumb but i dont think they even make drop spindles. i havent found them anywhere
Old December 12th 2005, 04:32
Eurolook71 Eurolook71 is offline
In super beetle world, when you talk of lowering, spindles dont count anymore. www.toplineparts.com <===visit here to view all your options. There are several ways to lower your super:
1)cut the springs:
ghetto superstar! Cut a few coils out the spring, very bad idea, totally kills the ride, and is bad for the suspension
2)lowering springs:
here's a start. Check out topline. Top of the line products for supers. they offer regular springs, and tapered sport springs, which tapper in the center, to allow a larger offset wheel to be used, but it still limited to how much clearance you are allowed.
3)adjust-a-strut the first adjustable strut for supers. started by topline, copied to hell. 3-bolt allows up to 5 inch drop, 2-bolt later style allows up to around 3.5-4 maybe. Very safe, effective way to lower your super. Once this came around, topline discovered ways to rearrange the suspension geometry with little tricks here and there...ie caster-fix bushings for the swaybar, off-center hole in bushings forces swaybar more forward, making up for the natural pull rearwards the suspension causes when lowered.
4)MAXX struts, skinny coil-over style setup, allows use of large + offset wheels (ie prosche) more tricks in perfecting suspension geo, bumpsteer kit, toplines caster+ kit, etc.
Main rule:
do everything right the first time. And do not try and setup a suspension with new coil-overs, etc until everything else is inspected, repair/replaced/upgraded. This goes for tie rod ends, ball joints(tears in rubbber boots=bad), bent/damaged tie rods, bushings (meaning ALL the bushings, especially that idler arm bushing, this is the main cause of the shimmies! Replace everything!!!
Again, check out www.toplineparts.com....
=EuroLook71=
71' Super Beetle
1.6L DP - Kadrons, stock heads P&P by me
Old December 12th 2005, 13:00
If your going with option #3 or 4 then you'll want one of toplines sway bars for lowered supers, your control arm bushings will thank you.
