Old August 22nd 2006, 14:32
Bullyboy Bullyboy is offline
FS 46mm Kadrons
1 pair 46mm Kadrons done by AJ Sims @ Lowbugget.com (1 seasons use).
$400 CDN plus shipping from Canada
46mm throttle bodies c/w urethane/vinyl bushings
CNC 32mm venturies
air top kit adds up to 7cfm
Vent Kit that will allow you to run as hard as you want without that stumble.
155 main jet, 55 idle, and a 175 air correction jet
also tapped for a vaccum advance
Scat linkage
Welded and ported manifolds
If you buy from Lowbugget they are:
$589.99 46mm and Power kit (air top, vent kit, CNC vents, bushed throttle assembly)
$50.00 Scat linkage
$40.00 Tap and install vacuum port for vacuum-advance distributors
