Old November 4th 2006, 21:06
elev8_dude elev8_dude is offline
Power Problems (Something with Distributor)
Okay, recently I've had to replace 3 ignition rotors and 1 distributor cup. I've ground the block to the body and still problems. I have flat spots at high rpms, I've lost some acceleration and performance. It feels like its running out of gas in all RPM ranges. I need some advice and quick, I've lost my patience. It use to run sweet and then......
I've recently has it timed, valves adjusted, carbs sync, heads tighten, and I've added fuel additives to clean carbs and line. I have suspicions my distributor is the problem. Either I need a new one or tweak and upgrade the one I have.
1915 CC
MSD 6AL
MSD Blaster Coil
009 Distributor
Petronix Ignitor
Stock plugs and wires
Optima battery (red)
Dual 34's
