Old April 22nd 2007, 23:07
levi20AE's Avatar
levi20AE levi20AE is offline
getting the most camber from a STD type 1
Other than the more eccentric camber caster adjusters available how can camber be maximized on a standard ball joint front-end? What are you guys running as far as caster and camber settings?
Currently running:
CB dropped spindles
Weld-in torsion spring adjusters
Caster shims
Eccentric camber/caster adjusters
70 Std. Beetle
03 20th Annv. GTI
