Old February 29th 2008, 23:23
AggieDave AggieDave is offline
New wiring harnesses?
I've decided to tackle the scariest thing about my '73 Super's rebuild, the wiring. Its a complete rats nest of "custom" work and "repairs" by the previous owners. When I got the car back in '95 the electrical was screwed. I patched it together best I could to make it work right and even then it wasn't all that reliable. So now that I'm doing as complete of a rebuild you can do and leave the body on the pan I'm looking at the wiring and longing for a correct and complete setup. So I've been looking at Watson Street Works' wiring harness. It looks compelling, modern relays, fuses and a seemingly easy to follow wiring instructions; however, I'm not an electrical guy and its really intimidating.
So I leave you with this. If you were going to rewire your bug and you weren't smart enough to simply build your own wiring harness from scratch, which "kit" would you go with?
