Old August 23rd 2007, 15:56
hak134 hak134 is offline
Spare for Porsche Rims
Hey guys...
72' SB is lowered and front end rebuilt! I have purchased Twists...7's for the front and 9's for the back. And I will have discs all the way around.
My question is in re. to a spare. For those of you with the different width rims...
Are you all purchasing a genuine porsche spare tire? Or are you actually purchasing an extra 7 and 9" tire? or just purchasing a 7" and using for the rear incase of a rear flat?
Hazen
Old August 23rd 2007, 18:17
Porsche pattern space savers come up on Ebay often, they are the type that needs to be inflated, but they give you more space in your boot or you could have a Porsche pattern centre welded into and existing VW wheel new. You could also find a skinny Fuchs wheel for a spare but they can get expensive.
For my daily driver 1303 I have a 16 inch space saver wheel from some sort of jap car, I had a steel plate made up and welded in the centre, it has 3 stud patterns in it. 4x130, 5x130 and 5x100. Its the pre inflated type but is very skinny so it fit in the stock spare wheel hole nicely.
For my other 1303 I have a alloy Porsche space saver.
Old August 23rd 2007, 21:02
http://www.germanautodismantlers.com/
They are in northeast GA. They have ALL kinds of spares sitting around.
Old August 23rd 2007, 22:46
Scotts73SB's Avatar
I hear the collapsable spare will fit in the "boot" (front trunk) if your car is the kind where the spare sits flat..not upright.
Old August 23rd 2007, 23:08
I had a steel Porsche space saver in 72 model beam car with no problems, but it had never had a hit in the front.
Old August 24th 2007, 09:48
I'm using one of these Porsche "skinny" spares on my '69 Standard. It's a 17" rim, but matches the overall height of my 16" Fuchs and tires -- and it fits in the spare tire well. Mine is brand new. I paid $75 for it on eBay...
Kafer_Mike
Old April 19th 2008, 05:44
666bug's Avatar
666bug 666bug is offline
I have been told that if I remove the tyre from the Porsche space saver that it is possible to fit a standard 15" radial tyre..( Original tyre wont stay inflated)...But the local Porsche dealership says "not possible" please pay us $800 (AUD) for a new one! Any advice ?9Beetle is fitted with Porsche 5 stud pattern...
Old April 21st 2008, 15:11
Chisel86's Avatar
Chisel86 Chisel86 is offline
I don't see why not. The dealer is probably saying that for liability reasons. The collapsible tires that are mounted on them are 165's so I would assume you could fit "regular" 165's, 145's, or maybe even 135's on them. I have no personal experiance with them so don't hold me to it.
[SIGPIC][/SIGPIC]
1302 Super (O\!/O)
Old April 21st 2008, 15:38
icekoffee
Is there any difference between the 944, 928 and later 996 or Boxter spare rim? I see alot of 944/928 rims on Ebay cheap, but not many 996/Boxter as mentioned above. I'm looking for a spare for a 5-lug converion on both a 914 and a Karmann Ghia... smaller the better...
Old April 22nd 2008, 21:07
You can fit standard 15" tyres to the 15" spare steel rim for sure. In the UK there is a guy who runs these all around on a bus
