Old June 11th 2009, 03:48
blitzvw's Avatar
blitzvw blitzvw is offline
Porsche 924 rev counter help
Hi guys, I have a Porsche 924 rev counter that I would like to wire into a Beetle/Type 3
The one that I have is from a '77 924 and has 3 terminals at the back.
One that says +12
One that says 1
One that says - (minus)
What goes where? Can anyone help?
Blitzem with Type 4 power
Old June 11th 2009, 07:12
evilC's Avatar
evilC evilC is offline
A guess?
+12 is to the +ve on the ignition switch circuit
- is earth
1 Is the feed from the coil
Does the unit have a separate circuit for the internal lamp?
Old June 11th 2009, 08:10
blitzvw's Avatar
Yes, it has two plug on connectors for the lights. I guess that you could pull current for those lights from the speedo lights.
Can anyone confirm that it is indeed the correct way of wiring up?
Old June 11th 2009, 10:18
That is how I would wire it.
12 to key on power +
- to gnd
1 to neg side of coil or tach out of CDI box
daisy chain the lights to the speedo lights so they will be on the dimmer with the speedo.
Old June 12th 2009, 03:09
blitzvw's Avatar
Good stuff, thanks
