Old June 14th 2009, 23:54
sved's Avatar
sved sved is offline
Mounting of a 911 fan setup on a type 4
Hi there is there a how to on this? extra parts needed? milling of the case ect. Thank you Dave
Old June 15th 2009, 12:49
No, mainly also because there are many, many different set-ups all with their own outer diameter, case breather machining, shrouds, etc.
Sorry...
Old June 18th 2009, 17:23
To Wally's point, do you know what conversion kit you are going with yet or is this full-on DIY? If the latter, you have your work cutout for you and will need to be very specific on what your plans are to get much online assistance. This is the crowd to help though if you can provide more info. Many on here have done them.
Old June 19th 2009, 00:15
sved's Avatar
Thanks I have a 911 shroud and fan coming but I do not know the size. I did find out that I will need bellcrank linkage. What I really would like is the setup wally has!! And yes it is a DIY. I made my Cali tins I think I can do this. thank you for replying I'm really in the dark doing this and will have lots of questions. Dave
Wally I thought you had a 71mm crank for that 2.2?
Old June 19th 2009, 02:12
Hi Dave,
No, I couldn't get any more stroke with the damaged alu oettinger cylinders than 66mm. Remember, this one hole on the underside of this one barrel, was difficult to brush off
Old June 25th 2009, 00:45
sved's Avatar
Ok now that I have my mounting ring and fan setup where do I measure to know the size? Dave
Old June 25th 2009, 09:14
OUter diameter of fan housing is the size. Most systems are however constructed around a slightly machiend down fan housing. Original 270mm, turned down to 260mm IIRC.
Even so, most shops have their own adapter plate and machine their own thing. I realy can't give you any more directions then this as I simply don't know or have machined anything myself...
Old July 7th 2009, 01:15
sved's Avatar
http://i275.photobucket.com/albums/j...d/DSCF0366.jpg
Wally this is the 911 fan I'm going to use 270mm Dave
Old July 7th 2009, 03:06
Okidoki.
Old July 12th 2009, 19:10
Axl's Avatar
Axl Axl is offline
Location: in a house somewhere in Calgary , Alberta , Canada
Are you dead set on having the 911 fan shroud ? Jake Raby at massive type IV makes a really cool type IV fan shroud that works better than stock . Its called the DTM (down the middle) shroud . Its been made for the type IV engine that has been fit into a type I . His store's website is http://www.aircooledtechnology.com/store/home.php . Check out his whole catalog , as he has some really cool stuff . Steve .
Its a shame that 1/7th of our lives is spent on Mondays!!!
Old July 12th 2009, 20:16
sved's Avatar
911 shroud
Yes that is what I want to put in this. Yes I know Jake I have chatted with him on the web. I do like the dtm but, there is no room for any intercooler, with the Dtm or my current 36hp style shroud. I have no room in my current cars engine bay. I really like the setup wally has, But they are harder to find and $$ for shipping if you can find one.I did have a chance to buy a used Dtm. Thats all Dave
Old July 13th 2009, 00:38
Axl's Avatar
Axl Axl is offline
Cool ! Sorry I couldn't be any help then . Good luck with your project . Steve .
