Old April 29th 2010, 16:22
marco the T.S.E marco the T.S.E is offline
Pro Turbo fuel tank adapter :)
ok, so this is the ProTurbo tank adapter im now selling
it has 4 X 3/8NTP outs, that ill allow from -6 to -10 so you can run two -10 out to your efi fuel pumps, a -8 return and a -6 to drain the fuel from your tank perfect
or
if you only want one out, just plug the ones your not using with NTP plugs
you can use the standard intank filter and washers
This it the highest flowing adapter out there, all the passages are as big as you can get from a stock vw tank
there £40 each
unfortunatly it wont fit a Super beetle tank, but if i have 5 or more requests il make some up
Old April 29th 2010, 17:28
Shameless plug, but very cool part nonetheless
Doesn't fit a Super! Shame on you not incorporating this into the design in the first place! What were you thinking!!
Do you have any installed pics? as I have a hard time seeing this before me. Is it a 'weld-in' type of thing?
Oh, I think I need a nice alu swirl pot to which I can connect the above part. Sell any of those too maybe?
TIA,
Walter
Old April 30th 2010, 04:33
hi Wally, it screws strait on to the standard tank out(no welding!)
Super beetle has a 20mm x 1mm thread on the tank(if i can remember correctly! am i right?)
there is no other fitting on the market that does what this one dose for a stock tank, thats why im making them
thanks
marco mansi.........M.M.P
Old April 30th 2010, 11:08
And I just welded / drilled and tapped my tank last night for a -8 outlet.
You're 1 week too late Marco ! Very nice part BTW.
Old April 30th 2010, 17:37
Not sure about that thread? I thought to remember that a superbeetle (or any late model) doesn't have screw-anything, but just a 5 or 6mm outlet pipe bronze-welded at the underside of the tank
I did remember filling the tank with water for the most part and welding on a 10mm pipe onto it as a main outlet to the efi pump and using the stock 6mm as a return line...??
Old May 1st 2010, 04:37
Very good bit of engineering.
The early supers had a threaded bung to access the in tank filter, these were deleted in about 1973.
Could a similar unit be made that could be bolted to the bottom of a super tank, after drilling hole in the tank?
Old May 1st 2010, 08:38
randyj randyj is offline
I want one for a 75 Super!
Randy
Old May 1st 2010, 21:52
3 for my 1303ss! Great stuff.
T4 2666 1303s
Old May 2nd 2010, 04:33
666bug's Avatar
666bug 666bug is offline
fuel tank adapter
Hello,
i will have one for my 1303 1974 super please is that five and how do i pay for it ?
thanks,
Cameron
Old May 6th 2010, 14:10
ok! so ive had quite a fue requests for a fuel adapter for a superbeetle, but i need some info before i make some up , it looks like the only place to put one is in the factory filter placement but do all supers come with that filter? also is there enough room under neath (say 2in) for the adapter, also what thead do they use?, i need this info before i make some up!!,
thanks
marco mansi
Old May 11th 2010, 03:04
DORIGTT's Avatar
DORIGTT DORIGTT is offline
Marco, you've got a PM.
