Old December 2nd 2010, 03:51
SCCAbeetle SCCAbeetle is offline
Making a non-super handle
I know that a regular beetle probably cannot handle as well as a fully tuned out super beetle, but I can get it pretty darn close right?
What all would I have to do?
Is it possible to make a regular beetle handle on the par as say a more modern car?
I have a 1970.
Also, stupid stupid question, can you drift a beetle?
Old December 2nd 2010, 08:55
evilC's Avatar
evilC evilC is offline
Fundamentally, the BJ/LP trailing arm design is miles behind the Macpherson strut design and it is doubtful whether you could get close to the same performance in any empirically assessable way.
For a good read:
http://www.amazon.com/Modify-Volkswa.../dp/1903706998 and
http://www.aircooled.net/gnrlsite/re...s/handling.htm
Whether you can get a beetle to handle as well as a modern car is also doubtful, irrespective of whether it is a BJ/LP or strut front suspension especially as the design is 40 years old at best, 80 years old at worst. Your '70 beetle will be a swing axle rear that is definitely an 80 year old design that no modern manufacturer would consider. Even the IRS rear is old hat that having been superseded by multi links that do not toe-out in roll for example. Porsche have tamed the wayward 911 IRS rear with multilinks.
All you can do is make the car handle the best it can within the bounds of its ancient design. Its big advantage is that the light weight coupled with the potent power that can be extracted keep it a plausable contender.
You could drift any car with the right modifications. Check out 'You tube' for all the videos.
Old December 2nd 2010, 22:42
For a good read:
Its an IRS pan.
I was thinking that I might have to invest in a Mendeola suspension if I really want to make this thing handle.
Now come to think of it my best bet is to make the thing a GL street fun car not super fast and call it a day, get my hands on a 130X (2 or 3) and go to town on that.
Old December 3rd 2010, 04:28
judgie's Avatar
judgie judgie is offline
you can make the bj/irs into quite a good handeling car. well a predictable one any way. 2 inch drop all round and adjustable anti roll bars at both end, some good shocks [my choice would be bilstiens] make sure all the bushes and beam bearings are new. then get a good 4 wheel alignment done and experemnet with the settings. The biggest singlle improvement will be some decent rubber on not to wide wheels, i wouldn't go above a 7" wide rim and even thats prob to wide for the front. I see it all the time on the tracks that folk spend thosands on trick suspension then bolt on a set of worn missmatched tyres and wonder why the car wont do what they want. Even a modern 911 will be bad with the wrong tyres.
Old December 3rd 2010, 05:10
Yeah I know how important wheels and tires are.
My VW is taking a... modern Japanese esque route. I would like it to handle and put a decent zippy little engine it, more for spirited daily driving then anything else.
Old December 3rd 2010, 14:50
oasis's Avatar
oasis oasis is offline
... then get a good 4 wheel alignment done and experemnet with the settings. The biggest singlle improvement will be some decent rubber on not to wide wheels, i wouldn't go above a 7" wide rim and even thats prob to wide for the front ...
I'm glad you made that point. I had 6½'s front and back on my 1302. I liked it a lot but, honestly, I have no idea what would be ideal for a Super or a standard. All I knew was whether I was having a boatload of fun or not. Most of the time was YES.
I'm guessing engine choice and brake/suspension set-up plays an important role, too.
Do you have a general guideline with which one should follow?
(2004-2008): 1971 1302 w/2056
Old December 13th 2010, 14:40
redhot redhot is offline
A question on the side;
side-loads on a standard beetle should transfer through the center torsion bar lock piece to the front beam itself. Has anyone seen any failures on these parts? When one start putting on sticky wide tires and use the car much harder than ever intended it looks fragile (but from experience it is not though)
Old December 14th 2010, 12:58
redhot, its not an issue, ive raced both k&l and b/j beams in many disciplines from grass track to rallycross, and circuit racing, all had various means of adjustment, none have ever failed, these days i do preload the arms against side loads with the correct bushes.
they were of course proven by military use in w/w 2 with the kubel and schwimmer, long before we got to lower them with swayaways....
Old December 14th 2010, 14:40
The reason for asking is some debate as to how good the generic no-name Puma beams are. The original beam has a depression in the beam itself, gripping into the centre-piece. The Pumas does not, as far as I have seen, this. Only thing then holding this is the shear force from toothed-plate and if that fails the bolt itself shearing against the beam.
Would be nice to see how you made the preload bushes and installation.
Old December 15th 2010, 13:08
redhot, i see what you mean, and a very good point! ive never even noticed how the anchor is fixated in the generic puma types, and I've fitted enough of them, but again ive not come across a problem, and my own beams have swayaways by choice. i should have some of these centre sections in the 'useful scrap bin'... time to investigate further...
Old December 16th 2010, 14:15
This standard beetle seems to have no issues with handling
http://www.boxergasse.com/html/stefa...tschinger.html
The on board video is pretty amazing as well, indicating that the base BJ suspension is well suited to the task at hand.
Once I get my car back on the road (spring 2011), I'll be able to log G's with my LMA3 and post some data.
Old December 16th 2010, 16:48
Hi Sandeep, Expensive kit there! Kevlar wings and all, i don't see an ARB on it, maybe its in mid build, its also possible to build a T/B beam so stiff on the leaves it may not need one, that's if it even has leaves of course, looks like the end housing of a R&P projecting in by the coil over, complete with tender springs. Nice to have all this kit, but open regulations allowing it in the kafer cup in the first place meant it was unsustainable, most competitors where VW traders, and even they blanched at the expense, amateurs could not compete, and of course it led to the demise of the series. but i digress, it would be nice to see some more technical pics anytime soon!!
Old December 16th 2010, 17:25
Some of the issues facing BJ cars compared to strut cars is the lack of steering lock and that the front track on BJ cars is very narrow.
For predictable handling you need a wider front track than than rear track otherwise the car handles like a trike (exaggerating here) and wants to fall over in the front.
I'll explain, imagine a trike with the single wheel leading, they are very unstable when turning and fall over very easily, watch Mr Bean episodes with the 3 wheel car. Now reverse the trike with the 2 wheels leading and the 1 wheel trailing and you get much more stable turning.
Its best to do what you can with you have with advice offered on this forum.
Old December 17th 2010, 14:15
DORIGTT's Avatar
DORIGTT DORIGTT is offline
Am I imagining things? In that picture, it appears that there is a 'spacer' of sorts on the lower arm, but not the upper. Would this thicker 'spacer' allow greater negative camber because it changes the vertical axis of the spindle assembly? If so, that was sneaky.
Old January 4th 2011, 22:29
I think you are correct as further investigation on the site reveals what looks to be through bars / bolts replacing the front torsion leafs. I can't post the pic but the information is there.
I wonder how the track handling would compare to an A-Arm suspension ... surely the BJ set up with those lower spacers would handle better than a stock beam. You would also be able to fine tune the camber with that set up. Stefan Naumann's car on the site also looks to be using this modification.
I'll have to talk to Lanner about ths .. looks like a simple mod.
I wonder if anyone has any camber / castor curves for the stock BJ suspension
