Old February 5th 2011, 05:39
-Alex- -Alex- is offline
Porsche 944 turbo brakes on BJ beetle
This must been talked many times, but i havent find any good answers yet. How to install 944 T brakes to a stock height BJ spindles? Especially the bracket i am interested.
I am designing this setup for a friend, and i suggested that new hubs are made and rotor will be porsche rotor 282x20,5 or 282x24. I have started to design the hub.
Does the spindle need machining? Is it possible to make lasercut bracket? I plan to make it out of finnish high strenght steel, which yield strength is 650nm/mm2
I have 944 turbo rear calipers, that friend wants to buy them, is it wise to put these to front? If stock calipers have 40mm pistons, these turbo rear calipers have about 10% caliper area and the pads are 1,5x bigger.
Old February 6th 2011, 03:39
MX67 MX67 is offline
I've done bracket and the whole 944 conversion on BJ just printing this article and bringing it to local machine shop.
http://germanlook.net/html/tech/Tech...akeUpgrade.php
It's all inside
1967 Bug
Old February 8th 2011, 09:12
evilC's Avatar
evilC evilC is offline
The 282mm discs are not big enough for the 944T calipers that are more suited to the 300mm disc. I have fitted 928S4 (944T) rear calipers on a 289mm disc and had to ease the fitting.
