Go Back   GermanLook Forums > General > Members Rides
Old January 1st 1970, 00:00
Panelfantastic's Avatar
Questions about Panelfantastics ride
A work in progress. A lot of the unseen stuff to make GL (suspension,brakes,eng) before anything visually GL.
No current VW projects
54 Chevy wagon LS2 AWD
56 Chevy Panel "Lost Cause"
VKG Bastage child
Old March 23rd 2005, 17:25
justdubbin's Avatar
Jeff, I've just been looking on VKG at the pictures of your bus.
I'm interested in what set up you are using on the front suspension?
I'm planning on using King & link to retain some comfort, after all my bus is a daily driver and you guys from the UK all know about rock hard suspension and UK roads
Rob.
Old March 26th 2005, 00:09
Rob, I'm using a 4" narrowed beam with dropped (some call them "flipped") spindles. I've removed all of the small torsion bars from the beam and only left in the center ones on top and bottom. Normally this would slam the front to the ground and give you no suspension but I fitted coilover shocks in place of the regular shocks. The coilovers now control my ride height and are adjustable.
VKG Bastage child
Old March 26th 2005, 21:14
justdubbin's Avatar
Jeff what make and spec are the coilovers you use, the roads you drive on must be 100% better than UK roads but what sort of ride do these give?
Cheers
Rob.
Old March 27th 2005, 00:34
The brand is QA1. They are a universal coilover used on streetrods. I think I used one of the lightest springs they offered since I still have some torsions left.
The ride is a little stiff, but that was what I was looking for. It isn't bone jarring harsh, but it is stiff.
As for the roads here... the highways are usually excellent, but the local roads aren't anything to brag about. Some serious wheel bending potholes.
http://www.qa1.net/
VKG Bastage child
Old January 3rd 2006, 19:20
flat flat is offline
Jeff,
What is your rear suspension/transmission setup? I'm considering an IRS setup on my panel, and am trying to do some research.
www.vdubengineering.com
