Old April 13th 2013, 18:38
onixbonilla's Avatar
onixbonilla onixbonilla is offline
915 shifth rod coupler?
Hi! We are installing an aluminum 915 on a Type 1 chassis using the Bugat5speed parts including their Type 1 shifter, the one that relocate the shifter rod lower in the tunnel. Any one had used it? Do the Type 1 shifter rod works without modifications? Which shifter coupler we need?
Old April 14th 2013, 03:02
T5WOB's Avatar
T5WOB T5WOB is offline
hi i just fitted bug @5 speed set up .up have to cut the beetle rod .but vw made 3 different laths . i could not find out how much to cut out .its trail fit .i used the bug at 5speed shifter .dont think any thing works .there is lots of info on bug 5speed site .hope this helps regards martin .
martin.vw@btinternet.com
kerb$ide ku$toms
Old April 14th 2013, 03:38
T5WOB's Avatar
http://www.bugat5speed.de/en/projekt...ng-bug-5-speed
kerb$ide ku$toms
Old April 14th 2013, 04:07
dub_crazee's Avatar
I used the beetle rod and coupling. With both the box and the rod is situe, and the coupling on the gearbox, you can figure out how much you need to shorten it by. I also shortened the rod out of the gearbox and redrilled the dimple. After I did this I decided the porsche coupling was better as it has adjustment so I spliced the beetle rod with the porsche one! There are some pics on my build thread
Good luck
Classic Car Revivals
www.classiccarrevivals.com
Old April 14th 2013, 05:20
T5WOB's Avatar
dub_crazee how do you find 1st to 2nd gear .i finding it hard to find 2nd gear . any info would be good thanks .
kerb$ide ku$toms
Old April 14th 2013, 05:47
T5WOB's Avatar
http://www.germanlook.net/forums/showthread.php?t=9153
kerb$ide ku$toms
Old April 14th 2013, 06:42
dub_crazee's Avatar
Partly the reason I went over to the porsche coupling, as it takes a lot of minor adjustments to get it just right. If I was to do the conversion again, I'd use the 915 shifter I think.
Old April 14th 2013, 10:07
T5WOB's Avatar
ok thanks .i fitted the bug @5 speed one .very nice and well made .
kerb$ide ku$toms
Old April 24th 2013, 22:38
Thanks for the answers. We get the oem 915 rod/coupler and will made and hybrid one.
Old April 26th 2013, 08:58
T5WOB's Avatar
i fitted this one http://limebug.net/product/view/1503...earbox-linkage
kerb$ide ku$toms
Old May 1st 2013, 11:57
dub_crazee's Avatar
I am currently running the bug@5 speed one too. Agreed it is well made, but in my opinion, puts the gears too close together, hence why i say i'd now go for the porsche shifter. Turbo nutter is running a beetle shifter which seems to do the job also (coupled with the porsche coupling)
the limebug coupling looks nice, but doesnt offer the adjustment of the porsche coupling.
Old May 2nd 2013, 10:44
T5WOB's Avatar
any pics of your set up please .i fitted bug @5speed one ..but would like a different set to .finding 1st to 2nd .a pain .
kerb$ide ku$toms
Old May 3rd 2013, 02:53
dub_crazee's Avatar
What do you want pics of exactly?
change to the porsche coupling and you;l be able to get the adjustment you need. If you use a beetle style coupling, you have to drill the locating dimple mm perfectly in the right place!
Old May 3rd 2013, 10:18
Bug@5speed(US)'s Avatar
Some comments
- if ur running the beetle shift rod then u have the following option:
Cut and graft on the back end of the Porsche shift rod and that enable u to use porsche or after market shifter coupling
Or csp shift rod shorting kit on a beetle shif rod and use the vw coupler and some new bushings.
These are the more simpler options. There are others that are a function of creativity and what's available.
If u are using already a Porsche shifter then the easier route is to use the Porsche shift rod (have a goodbused one if need) and mate to Porsche coupler. Can't remember the length difference and how much has to be shortened or extended.
Alex Olaverri
Email: Bugat5speed@yahoo.com
Tele: 973 204-5463
Old June 8th 2013, 23:15
Thanks Alex! We ended buying the 911 shift rod. Will build a hybrid one!
