Old July 1st 2015, 02:13
Clatter Clatter is offline
Can the traverse be used as a jack point?
It looks like it's strong enough....
Anybody done this yet?
I need that jack point back there!
Even if it might mess up the new finish....
Old July 1st 2015, 03:45
Strong enough I guess, you could bolt on a steel plate where the jack would touch it to preserve it
Old July 2nd 2015, 01:34
Steve,
Have you jacked your car up this way?
Seen anyone who has?
Scary.....
Old July 2nd 2015, 03:36
No I haven't but I'm sure somebody has, I have solid piece metal that I use, you can see it near the Porsche mount that I use to jack the car with
Old July 6th 2015, 11:16
An excellent way to do it - make an alternate jack point.
I have a heavy type 3, and if that traverse bent I would cry real tears..
Old July 7th 2015, 04:53
Gerrelt's Avatar
Gerrelt Gerrelt is offline
I've made jacking points out of a hockey puck and an exhaust clamp:
I removed the standard jacking pionts, because they are worthless and prone to rust. So I had to have an alternative.
This method might be a bit more difficult if you beetle is equiped with a rear swaybar.
Greetings!
________Gerrelt
________homepage:gerrelt.nl
