Old January 21st 2016, 12:23
graham's Avatar
graham graham is offline
1303 floor pan dimension ?
Wasn't sure where to post this question but...
Does anyone have a bare 1303 floor pan, I need a measurement from the rear of the torsion tube to the end of the frame horns.
Any help would be much appreciated.
gee dub
Old January 21st 2016, 15:26
Nah, no loose floor pan but my engine is out, so then measurement would be easy then too right?
Rear of torsion tube is against the tube vertically?
Old January 21st 2016, 16:11
don't forget it necks in for the splined section..
Old January 22nd 2016, 01:26
graham's Avatar
Thanks fellas, I ve sent you both pm's .
gee dub
Old January 22nd 2016, 01:33
cookvw's Avatar
cookvw cookvw is offline
i have a bare 1303 pan that i can get measurent for ya.
Old January 22nd 2016, 04:36
graham's Avatar
Ah thanks CookVW that would be great. As Ricola has said the torsion tube necks in for the splined section so if you could please give the dimension from the main/large section of the torsion tube that would really be helpful.
Graham
gee dub
Old January 22nd 2016, 16:37
Any good.
http://www.eagleownersclub.org.uk/Te...dimensions.jpg
Old January 22nd 2016, 17:36
graham's Avatar
Originally Posted by spannermanager View Post
Cheers Spanners not sure if I can get it off this drawing though as its not to scale. Ideally i need the dimension from the back of the torsion tube to end of the frame horns. The drawing here only shows it to the inside of the pan and the body is on my car. If any one is wondering why I don't just measure mine its because the frame horns have already been removed
gee dub
Old January 25th 2016, 23:47
cookvw's Avatar
i will get you the needed dimensions in the morning and ill post them up asap.
Old January 26th 2016, 17:57
graham's Avatar
Thanks for your response cookvw but I've sorted it, as you can see Steve C has had his measuring stick out
Thats what I like about this site/forum, you post a question, it gets a handful of views and within a week people are jumping in and helping out .
gee dub
Old January 26th 2016, 01:10
Hi Just measures a spare 75 1303 pan at the side of my garage, its 53cm, thats from a straight edge across the ends of the horns to the torsion bar tube just out from the pivot box
Old January 26th 2016, 17:50
graham's Avatar
Thanks for taking the time to do that Steve
gee dub
