HELP w/944T-IRS a-arm swap
Hey all,
I've got a 1970 IRS pan and am trying to convert to the 944T arms and spring plates. Challenge is, I'm having trouble getting the spring plate to sit on the spring plate. Has anyone else run into this? |
Is the original rubber still on the inner side of the 944 spring plate? If so remove this rubber and replace it with one for a beetle.
Are those Koni shocks the 944 versions? They have a larger lower bolt hole and smaller upper?
I have removed both the inner and outer rubbers and replaced them with the Volkswagen ones as I don't have the Porsche covers for the torsion housings.
To give an other posible answer to your problem. Are the torsionbars all the way in the splines of the springplate and the torsionbar housing on the chassis. ? Try cleaning the splines in the springplate to see if the torsion bar can go deeper. Hope this helps.
you need to use late IRS covers as well
