Old January 18th 2003, 19:31
Gunthner Gunthner is offline
progressive jet sizes
I have a Weber 32/36 DFEV (DFAV) progressive carb on a 1700 type IV in a 72' bus with a dual vac distributor. Does anyone know what size jets would (should) work best? Also, there is only one port on the carb for a vacumn hose from the distributor, where would the other one go or what distributor would be a good replacement? The engine won't idle down (below 1200 rpm's) and won't even die if I turn the mixture screw all the way in. Any help would be greatly appreciated.
Thanks in advance,
Gunther
Old January 18th 2003, 20:01
Massive Type IV's Avatar
Honestly, I have a super strong bias against these carbs, and purposely forgot everything I knew about the 5 years ago atleast..
maybe someone in the engine forum could help, my only suggestion will be of no help to you, so I'll stay quiet.
Jake Raby
