Old February 26th 2003, 05:43
richiep richiep is offline
Mallory Unilite Vacuum with Dells
Anyone know if you can use a Mallory unilite vacuum dizzy with Dellorto 40DRLAs?
If so, how do you dial in the adjustable Vacuum?
Thanks.
If its worth having I can't afford it.
Old February 26th 2003, 07:48
samcat's Avatar
samcat samcat is offline
I have been assured that you can.
I currently run a mallory unilite optical with vac advance. vac is disconnected (weber 40's at the mo)
I have a set of dell 40's which we are refurbing at the mo which I will be chucking on.
You NEED to take the vac signal from all 4 barrels (2 on each carb), and use the thing they have on an alfa for merging the signals and smoothing the pulses.
Cheers for now,
Sam C
Old February 28th 2003, 14:37
paul_f's Avatar
paul_f paul_f is offline
On the dells you only have one vacuum takeoff for advance, and the alfa part is an anti pulse valve.
Old February 28th 2003, 15:01
samcat's Avatar
Unless you add your own Gives a much stronger signal then
Yup, thats the one!
Cya,
Sam C
Old February 28th 2003, 16:46
paul_f's Avatar
So have you just drilled each barrell? Are you going to use 4 anti pulse valves?
If you have a Mallory dizzy I can't really see the point in doing this - you can adjust the advance for a particular amount of vacuum quite easily - surely it would be best to keep it simple like on the alfa?
Paul
